20 Most Recent Singer 5062 Mechanical Sewing Machine Questions & Answers
2answers
Where can I find the correct invisible zipper foot and shank for my Singer 5062C?
Any sewing supply store locally will have that
3/25/2017 3:52:23 AM • Singer 5062... • Answered on Mar 25, 2017
Presser foot lever stuck
You lever doesn't work because the presser foot Bar is seized from lack of use.Open the side of the machine to access the bar. Put a mixture of water and ammonia ( about 80%water 20% ammonia) on the top and bottom of the bar. Let it sit for 15-20 minutes then try to move the presser foot Up by lifting the foot with a screw driver. Do not pry so hard you break something. It should get progressively easy the more times you do this. Put some sewing machine oil on the top and bottom of the shaft and it should be good to go.
sewman7
3/20/2014 3:48:16 PM • Singer 5062... • Answered on Mar 20, 2014
Pressure foot lever is loose, is there a way to fix without taking it in for repair shop?
open he face and check the clamp screw. If loose raise foot to give 5/16" clearance and retighten after ensuring foot is in line with feed dogs slots
2/19/2014 8:35:38 AM • Singer 5062... • Answered on Feb 19, 2014
0answers
Manual free
Be the first to answer 12/16/2013 6:51:42 PM • Singer 5062... • Posted on Dec 16, 2013Be the first to answer
2answers
Birds nest under fabric
try a new needle
always keep a check on the thread take up lever, because sometimes the thread will come off & it can jam the machine up
clean under the needle plate for lint or loose thread & also the bobbin area
always check to make sure you have the correct needle for the fabric your sewing
6/18/2013 3:03:46 AM • Singer 5062... • Answered on Jun 18, 2013
J C Penny zigzag sewing machine model 6600
Am looking for the accessory parts that come with the JC Penney Model 6600 sewing machine any ideas?
4/21/2013 12:49:07 AM • Singer 5062... • Answered on Apr 21, 2013
I have the Singer 4562 and need more bobbins
The machine does take the class 66 bobbins.
2/4/2013 4:07:15 PM • Singer 5062... • Answered on Feb 04, 2013
I have a model 5062 and need more bobbins.
The Class 66 bobbin is the correct bobbin. The Singer part number, 172336, is specific to the 10 pack of their bobbins. This site, http://www.sewingpartsonline.com/bobbins-singer-apollo-class-66-172336.aspx , gives more details on the sewing machines that use the bobbin.I hope this helps. Cindy Wells
1/2/2013 4:31:05 AM • Singer 5062... • Answered on Jan 02, 2013
The bobbin will not wind
Mine did same thing,was told to wrap twice around the silver know where you normally wrap twice,make sure bobbin is all the way down.dont forget you start threading as if you were going to for top thread go thru first hook then over to silver know,but twice.hope this helps did me
12/24/2012 9:02:07 AM • Singer 5062... • Answered on Dec 24, 2012
Singer 5062 Mechanical Sewing Machine Logo
43 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
j c penny zigzag sewing machine model
  • Sewing Machines
