20 Most Recent
Nikon Telephoto AF Micro Nikkor 60mm f/2.8D Macro Autofocus Lens Questions & Answers
AF 55 micro NIKKOR f2.8 focusing ring broken
Same happened to me now after years of good use. My mother got this lens in 1987 so it's emotional. It still turns but it's hard without the grip. I'll try and glue the 3 parts of the ring back in place
AF 55 micro f2.8
Find an approved Nikon repair facility. You have to send it in for a quote. If you approve the repair (quote) they will repair it. If it is very old and they cannot repair it they will tell you.
ON DISPLY, APERTURE SHOW fEE AND DONT SHOOT
In all but aperture priority mode and manual modes you must set this lens to it's minimum aperture setting (i.e. highest number) to allow the camera body to fully control the aperture for you.
You'll also get this problem when using certain Nikon bodies which rely solely on electronic communication of the lens settings to the camera body (e.g. Nikon F75) as they lack the ability to read the mechanical linkages on the rear of the lens.
Error message
You might want to check the position of the aperture ring on the lens.
If it is not set at the highest number, ( IE smallest aperture, f22,f32
), then the camera will display that error message
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.
FULL 'make model (what it is)' in all questions please first 3 words.
Google
Nikon (model) manual
Read it it LEAST 3 times. Use the camera every day for a week and read it again.
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue:
Remove the battery from your camera.
Fully charge the battery using the Nikon D80 battery charger.
Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover .
If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f....
Most of the time, this
F Error message is limited to Nikon DLSR cameras. This particular
error message appears when the camera is not able to communicate with the lens.
To
fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place.
If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center.
I'm not a camera buff but I thought I'd pass this on.
other sites too....
https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web
Best to you.
