20 Most Recent Tumi Dakota Atech Digital 3 Sensor Watch Questions & Answers
Clasp no longer holds
What is the model of the watch? Thanks
12/23/2009 4:33:10 PM • Tumi Watches • Answered on Dec 23, 2009
I'de like to have a
Si porque tengo este reloj
4/17/2024 7:04:45 AM • Watches • Answered on Apr 17, 2024
2answers
How do i take my george watch out of 24 hour time?
how do you set the time on the digital george watches?
4/11/2024 7:38:43 AM • Watches • Answered on Apr 11, 2024
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM • Watches • Answered on Apr 07, 2024
BASE, METAL BEZEL STAINLESS STEEL BACK 10/4312-13 75311 THAILAND MOVT WATER RESISTANT 100F1 QUARTZ
Question edited for clarity. Please don't type in all CAPS, it is considered SHOUTING and is harder to read especially in a jumble of words and numbers. 377, although a maker would be useful! https://www.google.com/search?q=battery+METAL+BEZEL+STAINLESS+STEEL+BACK+10%2F4312-13+75311+THAILAND+MOVT ..
4/6/2024 1:45:42 AM • Watches • Answered on Apr 06, 2024
2answers
U.S. Polo Assn. Sport Men's US9061 Black Rubber Strap Watch. I need the INSTRUCTION MANUAL FOR bc534-1741el please.
No manual, just this. You can however just search by the number of buttons, 2 , 4 or 4. They are all the same. Google 4 button chronograph watch manual
4/5/2024 10:45:51 PM • Watches • Answered on Apr 05, 2024
Would like to check serial number on ferrari watch
yes
4/3/2024 8:07:40 AM • Watches • Answered on Apr 03, 2024
CANDINO WATCH 10965 PLAQUE G 10 WF. Is it made of gold please.
Question edited for clarity. Please don't type in all CAPS it is considered SHOUTING. No, they are gold plated. https://www.google.com/search?q=CANDINO+WATCH+10965 ..
3/22/2024 2:45:09 AM • Watches • Answered on Mar 22, 2024
POD Model:501 Digital Chronograph All Stainless Steel. Need instructions for a Pod 501 watch please?
Unknown make pretty much. Not available, so do it by the number of buttons. They are all made in the same Chinese factory. https://www.google.com/search?q=pod+501+watch+manual 4 button chronograph instructions https://www.google.com/search?q=4+button+digital+chronograph+instructions ..
3/20/2024 5:39:06 AM • Watches • Answered on Mar 20, 2024
Emporio Armani AR 0911 Watch. What type of battery will fit this watch please?
Question edited for clarity. Armani and Emporio in wrong order. Quality Watch... Best advice https://www.fixya.com/support/r27181038-changing_watch_batteries The same as the one in it if it has one. Battery for Emporio Armani - GP A76 / LR44 / V13GA Coin cell (Amount 1)
Emporio Armani products - BatteryUpgrade
BatteryUpgrade https://www.batteryupgrade.com > ... > Emporio Armani .. If you got it on eBay, it is a Chinese copy https://www.google.com/search?q=Armani+Emporio+AR+0911 ..
3/15/2024 3:49:43 AM • Watches • Answered on Mar 15, 2024
Mens Antler Wedding Bands
Your question is .................................
3/8/2024 1:20:46 PM • Watches • Answered on Mar 08, 2024
How do I set time.? No manual, remote does not work.
  1. Buttons on the Device: Look for any buttons on the device itself. Sometimes, there are buttons that allow you to navigate through menus and adjust settings directly on the device.
  2. Trial and Error: Try pressing different buttons on the device to see if any of them bring up a menu for setting the time. Look for buttons labeled "Menu," "Setup," "Clock," or similar.
  3. Long Press: Sometimes, pressing and holding certain buttons on the device can activate different functions. Try pressing and holding various buttons to see if it triggers a menu for setting the time.
  4. Google Search: If you know the model number of your Ultech device, try searching online for the manual. Many manuals are available for download from manufacturer websites or other online sources.
  5. Contact Manufacturer: If you're unable to find the manual online or if you're still having trouble setting the time, try reaching out to Ultech's customer support. They may be able to provide you with guidance on how to set the time on your device.
  6. Replace Remote Batteries: If the remote isn't working, try replacing the batteries. Sometimes, a non-functional remote can be as simple as dead batteries.
2/28/2024 9:57:13 AM • Watches • Answered on Feb 28, 2024
How to take links out of a metal band
It depends on the make. For some you need a pin press, and for others you use a small jewellers screwdriver. https://www.google.com/search?q=take+links+out+of+a+metal+band ..
2/18/2024 9:49:51 PM • Watches • Answered on Feb 18, 2024
Skmei watch 1163- Daylight savings time- how to set
To set the Daylight Savings Time on your SKMEI 1163 watch, first press and hold the "MODE" button for approximately three seconds until the "SET" mode appears. Then, press the "MODE" button again until you reach the "DST" mode. Use the "ALARM ON/OFF" button to toggle between "ON" and "OFF" for Daylight Savings Time. Once you have set your desired option, press the "MODE" button again to confirm and exit the setting mode. Your watch should now display the correct time, accounting for Daylight Savings Time.
2/16/2024 11:07:11 AM • Watches • Answered on Feb 16, 2024
Bottom of watch by second hand....what is symbol
You've probably heard people go on and on about the "sweep" or talk about how top quality watches don't make that tell-tale "tick-tock." For all intents and purposes, these people are right. When you pick up a Cartier or Chopard, the tiny hand measuring the passage of seconds glides effortlessly, like a toothless hockey player. In actuality, all wristwatches tick-tock. However, in a true quality watch, the internal mechanism (the movement) is so finely tuned and so well constructed, that these ticks happen as often as nine times a second, producing a flawless sweep. This is the difference between a five-dollar movement and a movement costing hundreds of dollars.
1/28/2024 3:10:21 AM • Watches • Answered on Jan 28, 2024
861237 women's watch how much is it worth
Not having a maker and just an abstract number makes it hard. Everything can be found on Google. https://www.google.com/search?q=861237+watch The Search Query is simply 'make model value'. ..
1/18/2024 8:42:47 PM • Watches • Answered on Jan 18, 2024
I have a sunbeam 882-1285 and can't set the chimes to match the time of day, need help
I have owned this exact clock for 30 years. Syncing the chimes with the time is very simple.1. Flip the second switch from "Start" to "Set."2. Use the thumbwheel to move the hands to the desired time.3. Use the four "H" and "M" buttons to set the time for the chime. — For example, if the desired time is 12:05, press the first button 1 time, the second button 2 times, skip the third button for 0, and then press the fourth button 5 times. — If the desired time is 9:00, you only need to press the second button 9 times (all unpressed buttons default to 0).4. When you're ready for the clock to begin using the time you've set, flip the switch from "Set" to "Start." That's it! It's that easy.
1/14/2024 7:34:18 PM • Watches • Answered on Jan 14, 2024
Tumi Dakota Atech Digital 3 Sensor Watch Logo
1 questions posted
Top Tumi Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Tumi Watch Expert? Answer questions, earn points and help others
View Most Popular
Tumi Watches
  • Tumi Watches
Most Popular Question
battery replacement
  • Watches
