20 Most Recent
ASUS MeMo Pad Smart 10 Questions & Answers
Turn off demo mode on asus memo pad
If it's the issue we had, that is an asus video clip plays over and over when the tablet isn't used, I found the solution. It's in fact a screesaver! so go to ASUS apps, and click screensaver, and deselect the screensaver check box.
Cheers,
Jeff
Unit stuck in sound demo mode
KINDLY BE PATIENT AND USING AN JUMP CLIP BY STRAIGHTENING IT, INSERT INTO THE RESET BUTTON AND WAIT FOR 5 - 10 SECONDS. FINALLY ANDROID SYMBOL WILL BE DISPLAYING FOR FEW SECONDS WITH SAND BAR. THEN YOU CAN ACCESS NORMALLY
I forget my pattern lock?so how will get return my
You will need to do a factory reset:1. With the device off, press and hold Volume Up and Power.2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.4. Press Volume Up continue.
It ask for a password to connect to my Wifi which
Are you able to connect to the internet through another device (TV, Blu-ray player, gaming console, computer/laptop, etc)? If so, how do you connect? I believe it's asking you for your network password, in order to connect to your network, which if you do not know, you can work with your Internet Service Provider, or call Asus Support for further assistance.
Instruction manual
Instruction manual should be on your device, either on Barnes&Noble or elsewhere...keep searching...don't give up :)
