20 Most Recent Necchi 4595 Mechanical Sewing Machine Questions & Answers
Try ebay for a parted out machine.
Necchi 4595... | Answered on Jun 07, 2019
Try the Necchi Yahoo Group. There are members who often sell parts and they also are very knowledgeable and helpful.. You should also try eBay. They have parts for lots of vintage machines. You may not find what you are looking for right away but look often as things show up everyday.
https://groups.yahoo.com/neo/groups/Necchi_Pfaff_Sewing_Machine_Collectors/conversations/messages?messageStartId=9&archiveSearch=true
Necchi 4595... | Answered on Jul 11, 2017
Tighten the screw under the plate near the feed dog
Necchi 4595... | Answered on Dec 29, 2016
There are many possibilitys
1- the needle and the fabric have to match - soft needle to hard fabric and the needle breaks - you need a needle with a higher number ex.90
2- not threaded correctly
3 - thread tension is too High to the fabric
look in the manual
good luck
Necchi 4595... | Answered on May 03, 2015
Hi most likely it is the Foot Controller that's at fault. This is the most commonest problem. Not the actual machine itself.
The "My machine started slowing down" is what gives it away, the ONLY thing that can cause a machine to slow down, is the controller, you most likely need to replace it, or at least get it looked at by a professional service man.
Take you machine in to a reputable servicing center for your brand and get them to look at it, ask for a "quote' for the repair.
If this doesn't prove to be the case then you may indeed have a seized motor, this would have to be replaced with a new one, that may prove quite expensive, however this will all be revealed after you get your "Quote". Which should explain what has been found, and how much it should cost.
Necchi 4595... | Answered on Sep 14, 2014
Needles made for different fabrics - are soft needle have a low number (ex.silk fabrics) and a hard needle has a high number(ex.canvas)
Make a test so you don't ruin the fabric or break the needles
god Luck
Necchi 4595... | Answered on Aug 17, 2014
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
Check the area that contains the bobbin. There might be something loose in there. While you\'re in there, clean an oil this area. Also, open the end cover (left side of machine) and lubricate the swivel arm top and bottom and wait overnight for oil penetration; you can also use a hair blow dryer to speed this up. For oiling diagram, see:
http://sewing-machines.blogspot.com/2009/11/necchi-zig-zag-issue.html
Necchi 4595... | Answered on Aug 07, 2014
There is loose thread hanging from the lower bobbin, isn't there?
Necchi 4595... | Answered on Dec 12, 2013
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric. make sure the correct needle for silk is being used.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
also clean under the needle plate & in the bobbin area for lint or loose
threads
check to make sure the feed dogs are completely in the up position
if none of these suggestions work then it's possible that the machine
is out of time & would have to retimed at a sewing machine shop
Necchi 4595... | Answered on Apr 16, 2012
Necchi 4595 Mechanical Sewing Machine Logo
65 questions posted
Top Necchi Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
refill bobbin
  • Sewing Machines
