20 Most Recent Juki MO-654DE Mechanical Sewing Machine Questions & Answers
0answers
Manual free
hi there just send to me email , i will send to you instruction manual for MO-654 , as you know this machine is very old , so PDF copy is not a good but not so bad. BEST REGARDS ASHRAF CAIRO - EGYPT [email protected]
1/7/2014 6:27:15 AM • Juki MO-654DE... • Answered on Jan 07, 2014
My needles broke on my juki mo 2512 how i replace it?
I've look for info on changing the needle & can't find any or a manualgo to the websites below & ask them about a manual or how to change the needle sewvacdoctor.coma1sewingmachines.com
9/19/2012 3:43:02 PM • Juki MO-654DE... • Answered on Sep 19, 2012
0answers
Tension
Be the first to answer 9/2/2012 10:29:24 PM • Juki MO-654DE... • Posted on Sep 02, 2012Be the first to answer
My right needle thread keeps pulling out on my Juki 655 - how do I fix this?
make sure the top tension is not to tightkeep longer thread tails for 4 to 7 incheskeep the thread pulled behind the needle before you start sewingsee if that helps solve the problem
6/5/2012 4:46:12 PM • Juki MO-654DE... • Answered on Jun 05, 2012
2answers
I need to know how to thread a Juki Pearl Line
sewusa.com has some threading diagrams
12/11/2010 5:26:24 PM • Juki MO-654DE... • Answered on Dec 11, 2010
Where can I get replacement upper and lower knives
I'm not in the UK,,but I suggest to look in the phone directory for a repair shop in your area
or try on ebay or sewingpartsonline.com or sewforless.com
11/27/2010 8:46:38 PM • Juki MO-654DE... • Answered on Nov 27, 2010
Breaking thread
there could be two things that I can think of right away, one the thread may be old, even if you brought it from the store, two, the needle is in the wrong way or it is the wrong needle .
11/11/2010 4:06:36 PM • Juki MO-654DE... • Answered on Nov 11, 2010
How do i fix the tension? i've been playing with
Try decreasing your stitch width and this should help. Put your tension dials on 4. Also make sure when you thread your machine your presser foot lever is up to allow you to get your threads through your tension discs properly. To test the tension (usually set at 4 on all 4 knobs) when you thread around the knobs pull the thread on both ends like you're using dental floss around the discs under the knobs so you can feel the pull (tension) on the thread. Let me know if this works for you.
8/23/2010 2:43:25 AM • Juki MO-654DE... • Answered on Aug 23, 2010
My overlocker thread tension is not correct how do
EBAY ITEM 160454752052
7/11/2010 4:50:09 AM • Juki MO-654DE... • Answered on Jul 11, 2010
Do you have a quick threading guide for this
Could not find. Here is one for the 634 that may help - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Raise the thread antenna and loopers to their highest position.
Set the tension controls to zero before threading.
Many sergers have the threading diagram inside the front door of the serger.
4/1/2010 9:41:04 PM • Juki MO-654DE... • Answered on Apr 01, 2010
Juki MO-654DE Mechanical Sewing Machine Logo
32 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
just got juki mo 654de threading
  • Sewing Machines
