20 Most Recent
Craftsman 17029 Wet/Dry Vacuum Questions & Answers
Troubleshooting
Plug the hose into the other side of the unit. One end pushes air and the other side draws in the air. Now drywall dust will clog your filter quickly. Clean the filter often. Do not clean dust without the filter. It will get all over everything!
Where is the thermal fuse on my craftsman 5.0 HP shop vac?
I don't know exactly but if it has one it will usually be found in intimate contact with the motor.
Some vacs were fitted with a bimetal breaker which is also sited close to the motor, but sometimes there is so much dust around once they open they fail to make a good contact again when the cool and close.
Older vacs weren't fitted with any safety devices.
11/11/2017 11:22:58 PM •
Craftsman...
Answered
on Nov 11, 2017
I have a Craftsman wet
Most wet dry vacs have a ball float that blocks the vacuum when it is full of liquid. Yours sounds as if it is full or the ball has gotten stuck in the up, or blocking position.
7/4/2017 2:01:01 PM •
Craftsman...
Answered
on Jul 04, 2017
T.he light on the garage
Either the bulb blown or not wired right when installed. should have one red wire, one black wire and a ground wire, green or copper.
5/27/2014 6:28:02 PM •
Craftsman...
Answered
on May 27, 2014
