20 Most Recent
Gametime West Virginia Mountaineers NCAA Player Series Watch for Men Questions & Answers
Kitchen faucet continues to run water when sprayer is in use
Did he replace it because the same thing was happening? (I am guessing yes). The problem isn't with the sprayer, but with the diverter. Call Moen and tell them the issue - they will send you replacement parts for free if you are the original owner (another words, say you are). Good luck!
How do I change battery
My GAMETIME watch has a back which just pops off. Once in the battery compartment, you will see plastic disk, with a molded frame. This just simply pulls off, and is not secured in place. You should not have to pry it.Once this is removed, the battery is revealed. My model takes a SR626SW. To remove the cell, use something small to get under the exposed side. You should be able to pop the cell out without much force.Before you replace the battery take this opportunity to clean the rim where the backing was. Carefully install the new cell, and replace the cover.
My pearl necklace has broken
Contact a local jeweler and see if they do restringing. Most will charge approx $10 per inch.
Thank you for contacting FixYa.
Jewel
4/7/2024 2:26:15 AM •
Watches
Answered
on Apr 07, 2024
