20 Most Recent
Brother XL-5600 Mechanical Sewing Machine Questions & Answers
Thread from the top needle gets pulled and tangled
change the needle
rethread the machine-make sure to get every thread guide
make sure the thread does not come off the thread take up lever
clean under the needle plate where the feed dogs for lint
also clean the bobbin area for lint & loose threads
My brother gxl 5600 won't work. It was given to
check the bobbin winder if it is pushed in to the winding position it wont sew no matter what elseyou do. Do you have the manual if so in the back there should be a phone number to call for a technician to assist you
Will not stitch correctly stitch length will not
Are you maybe stuck between two different stitch patterns? Check your manual for troubleshooting. If, you don't have your manual go to brother-usa.com and download one for free. They also have a frequently asked questions there. 1-800-276-8437 is their customer service help number.
Thread is catching & breaking somewhere inside
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
The machine will not pick up the bobbin thread
the flat side of the needle shank faces away from the side of the needle eye that you thread through. In other words, if your machine threads from front to back, the flat part faces towards the rear of the machine.
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
