20 Most Recent
Brother ULT2001 Questions & Answers
Upper thread keeps breaking on Brother ULT 2001
the tread gets stuck on in the thread take up arm, there is a joint ware the arm is rived to gather, the thread get caught between arm and the rived sheet steel . . take little silicon gasket and fill in the joint so thr thread can't get stuck where its rived
Quantum cxl timing problem
That will not be a timing problem. Most probably centre needle position has not been selected when using the straight stitch foot
Repair manual
If you recently purchased, perhaps seller has the manual. Doesn't hurt to ask. They may have forgotten to give it to you!
Jimmy
The feed dogs do not come up
Refer to your manual and you will see that you have to remove the free arm extension and there is a switch on the machine that must be pushed over to put the feed dogs up. If, you do not have your manual, go to brother-usa.com and download one for free.
