20 Most Recent
Brother IntelliFax-2820 Laser Fax Questions & Answers
What does comm error 20
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
11/12/2021 5:49:21 PM •
Brother...
Answered
on Nov 12, 2021
Paper jams at pickup from tray
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
10/25/2016 7:54:05 AM •
Brother...
Answered
on Oct 25, 2016
Paper keeps getting stuck
Get some paper dust cleaning paper from a an office supply company and run a sheet thru it a few times. It's sticky and will clean the rollers.
6/20/2015 10:29:19 PM •
Brother...
Answered
on Jun 20, 2015
AFTER CHANGING A CATDRIGE MY PRINTER IS NOT COPING WHY
Is it a name brand cartridge or a cheaper knock off? Some printers won't recognize a different cartridge even if it is the same size and shape. They make them that way so you have to buy the makers cartridge.
12/3/2014 4:23:47 PM •
Brother...
Answered
on Dec 03, 2014
