20 Most Recent
Texas Instruments TI-83 Plus Calculator Questions & Answers
On my TI 84 the
if you try to reduce the light on the screen and it dd not help
it could be a problem with the screen
if you want to fix the Calculator let me know
[email protected]
Jack
4/27/2016 8:42:13 PM •
Texas...
Answered
on Apr 27, 2016
Radian mode does not work properly
-1E-13 is a very small number. When doing this kind of a problem you can regard 1E-13 as 0.
Remember that pi is an irrational number. It is only estimated on your calculator. I just played around with a TI-83 and found the following answers:
cos(pi/2) = 0
cos(2*pi + pi/2) = 0
cos(4*pi + pi/2) = 1E-13
cos(20*pi + pi/2) = -1E-13
As you know, that correct answer to each of these is 0. The calculator gives non-zero answers because some very small errors are accumulating. There is nothing wrong with your calculator.
12/21/2014 9:54:27 AM •
Texas...
Answered
on Dec 21, 2014
Decimal to mixed number fraction
Isolate the integer part (to the left of the decimal point)
Convert the non integer part (decimal part) into a fraction.
Write the result as (integer part) (fraction part)
3/2=1.5
Integer part is 1, decimal part is 0.5
0.5 as a fraction is 1/2
3/2= 1 1/2
9/11/2014 9:54:53 AM •
Texas...
Answered
on Sep 11, 2014
How to find a log of a different base
Use the logBASE function available in the MATH menu. Press MATH, use cursor-left/right to select the MATH submenu, then use cursor-up/down to access logBASE.
6/8/2014 2:37:49 AM •
Texas...
Answered
on Jun 08, 2014
Invalid dim
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
6/7/2014 3:36:40 AM •
Texas...
Answered
on Jun 07, 2014
