20 Most Recent
Olympia Standard 300 Typewriter Questions & Answers
Why I can only type 15 letters in one line?
You probably have the right margin set there.
When you get to that point press but don't hold the mar rel key space to the location for the right margin press the R margin key.
DickyO
How to return
If pressing the return key doesn't do it you have a keyboard problem.
DickyO
Olympia splendid
Check the pitch slide switch it should be in 10 or 12 not PS. Slide it up & down a few times they do get dirty.DickyO
I have an address I
I belive That this T/W dose not have an addressable memory. Go toNADIDT.COM click on current models the ae710 is the same as your T/W.
DickyO
How to make a correction
Type a wrong letter, press correction key (X WITH AN ARROW POINTING NTO THE LEFT) should remove Mistake. If this dosen't work you may have very old supplies or a non correctable ribbon.
DickyO
