20 Most Recent Invicta Sea Spider Chronograph Polyurethane Stainless Steel Watch for Men Questions & Answers
You should use two extremely small flat head screw drivers to remove links on Invicta polyurethane watch bands. The smaller pens on the polyurethane watch bands have a notched cap (tiny screws) on each end .You must use one screw driver to hold the pen cap (screw) steady and the other screw driver to turn the cap (screw) counter clockwise. You only have to remove one notched cap (screw). These caps (screws) are very small and you should be careful not to lose them. Once you removed the cap (screws) you can use a small screw driver or paper clip to push the pens through the links. You should repeat this til you remove the desired links.
Invicta Sea... | Answered on Mar 23, 2014
mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
Invicta Sea... | Answered on Jul 03, 2010
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove watch bracelet links. Rate me, please
Invicta Sea... | Answered on Mar 10, 2010
Take your Invicta watch to a jeweler to have the misplaced battery replaced.
Invicta Watches | Answered on Dec 28, 2019
Could be that you have bent the crown shaft.....easily done, see if anyone will service it for you, sadly, many eatchsmiths won't touch INVICTA
Invicta Watches | Answered on Dec 16, 2019
Take it to a jewelry store, they have magnifying lenses to see where the parts go but here's a YouTube video showing the proper process for changing the battery,perhaps you will see the offending part you need to locate
https://youtu.be/hgeVHrZFUMk
Invicta Watches | Answered on Nov 03, 2019
It's not the size that counts, but type. Take your Invicta to a jeweler who will open it, identify the battery type, and perhaps replace it.
Invicta Watches | Answered on Oct 28, 2019
It could be a couple of things, the second hand is not seated properly and is rubbing. May need a cleaning, or fresh battery. Unless you have taken a watch apart I would bring it to a watch repair or send it directly to Invicta USA they will give you an estimate. Should not be expensive
Invicta Watches | Answered on Sep 29, 2019
Battery type, not size. Take your Invicta to a jeweler who will open it, determine the battery type, and perhaps install a replacement for a reasonable fee.
Invicta Watches | Answered on Sep 21, 2019
Take your Invicta to a jeweler to have battery replaced.
Invicta Watches | Answered on Jul 01, 2019
Invicta Sea Spider Chronograph Polyurethane Stainless Steel Watch for Men Logo
13 questions posted
Top Invicta Watches Experts
Janelle Schoonover
Janelle Schoonover
Kardoc
Tom Lambert
Level 1 Expert
Are you an Invicta Watch Expert? Answer questions, earn points and help others
View Most Popular
Invicta Watches
  • Invicta Watches
Most Popular Question
adjust band
  • Watches
