20 Most Recent
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Questions & Answers
Burner works intermittently
You have either a bad burner or a bad control for same, or bad connections.
With power removed use a pair of pliers to crimp the connections (after cleaning the ones on burner) going to the burner.
Range started beeping and display "F10" code.
Hello & Welcome to FixYa
Error code F10 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
How to check heating element
You can sometimes see the burnout of an element. In some cases it will actually burn a hole or melt a spot in the outer lining of the element. Sometimes it shows nothing. In that case it can only be tested with an ohm meter... Normal reading is approx 15 to 20 ohms. No reading at all means its burned out.
How do i open the oven windows to clean in between the 2 glasses
Assuming you've removed the door, lay it down on a blanket and look at the bottom. Usually there are 3 or 4 screws there - remove them. Then remove the 2 screws that hold the handle to the door. At this point, you should be able to separate and remove the outer door & glass panel. 90% of all your spills and drips can be cleaned at this point. I do not recommend taking the rest of the door apart, as it gets more complicated to disassemble and especially re-assemble correctly. If you need further help, reach me via phone at
https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC
(Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Ignitor isnt working
The oven ignitor should have a resistance reading of about 3.2 to 3.6 ohms. If the readings are out of this specification or show open replace the ignitor. measure the resistance of the oven valve. The gas valve should have about 1.5 ohms of resistance. If the gas valve is OK, the control board is suspect. The ignitor needs 120vac to work.
