20 Most Recent
Zenith Analog to Digital Audio Converter Questions & Answers
Dtt901 does not work. I unhooked it for a month,
Could be something to do with the date and time. It seems like they like to revert back to 12/31/14 fr some reason and the time will be off due do connection. Go to settings and first turn off auto time and then change date and change time and year then it should work ok.
Need the code zenith dtt 901
What code, I do not understand your problem. Please go into more detail. I have two Zenith DTT 901 converter boxes, each is on a 15" Sony TV. They work perfectly after I corrected a wrong setting on the menu.
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
We have a converter box. model number DTT901. we
I bought two extra remotes for my dtt 901. I can't remember where i got it, so google dtt 901 remote. Someone sells them. If you see any new dtt 901 boxes, let me know as one of mine just crapped out.
I couldn't program the remote
I have two DTT 901 converters. They are both set for two Sony 15" televisions (analog) and they work just fine. I would go through the menu as if you were setting it for the first time, check all settings, and see if that fixes it.
Hello , i have
What I would do: I would make sure the remote has new batteries, then I would bring up the DTT 901 menu and go through it as if you were programming it for the first time. Mine was going off by itself after an hour. Turned out it had changed the auto off feature from off, to one hour. I reset it to off and it is working fine. Maybe an electric spike has fouled the menu settings. Also very important to have surge suppressors on all electronic products.
My converter will not come back on
I had a problem with my converter going off by itself about an hour after I turned the TV on. One person said buy another, the circuit board was bad, wrong. What really happened was there is an auto off program that had somehow gone from off, to 1 hour. I reset the auto off to off and it works fine.
I installed the zenith Digital converter box
I understand your issue as not getting the Digital reception from your converter box. The antenna plays an important role in what you can get. If you still have the Amplified antenna try to reduce the amplification and readjust the antenna positions. You might have to do this several times until you get it right. Also, if you live in a city and not a rural location do not use an amplified antenna and see if it is any better.
Good Luck.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
