20 Most Recent Kenmore 95002 / 95004 Electric Kitchen Range Questions & Answers
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
Kenmore 95002 /... | Answered on Jul 16, 2017
Then its probably hot. With such a vague question. You get a vague answer. But really it could be the intimate switch for the element or if smooth top the element itself.
Kenmore 95002 /... | Answered on Jan 17, 2015
If all burners and oven no longer heat, you don't have 240volts supplies to the oven any more. Could be wire burnt off terminal block where the cord attached or could be that your household electrical has a problem.
Check to make sure the latch isn't bent - see if it lines up with the hole in the door designed for it. Also make sure the door hinges are properly installed and settled all the way.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore 95002 /... | Answered on Jan 03, 2015
If you take off the back and follow the wires.
Kenmore 95002 /... | Answered on Jun 05, 2014
You most likely need to replace the control and temp switch. It's not really safe to use you should have it done as soon as possible.
Kenmore 95002 /... | Answered on May 12, 2014
what is a infinite switch and where is it?
Kenmore 95002 /... | Answered on Apr 22, 2014
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Kenmore 95002 /... | Answered on Oct 25, 2013
Kenmore 95002 / 95004 Electric Kitchen Range Logo
201 questions posted
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Kitchen Ranges
Most Popular Question
oven flashing oven not heating up
  • Kitchen Ranges
