20 Most Recent Durabrand DPX3290L Player Questions & Answers
The portable dvd player stoped working with or without the cord
I would check the power cable to ensure that nothing is broken. Then get your multimeter out and check to ensure that you are receiving 12-14.4 VDC to the plug that is inserted into the player. If both of those check out then you know it is the player itself. If you determine that it is the player, then you will need to open it up. Chances are that one of the capacitors have failed. You can normally tell because the case is swollen or leaking. If this is the case then you only need buy another cap and then replace it if you know how to solder.
8/2/2012 1:43:51 AM • Durabrand... • Answered on Aug 02, 2012
Manual for dpx3290l
Check this link to download the manual.
6/8/2012 5:01:13 PM • Durabrand... • Answered on Jun 08, 2012
Durabrand DPX3290L video input?
HelloIf your XBox have AV out, you can connect it to your player using an AV cable, and select the input of the player to external AV.This is the picure of the AV cable.3_5_2012_12_25_22_pm.jpg
3/5/2012 12:25:40 PM • Durabrand... • Answered on Mar 05, 2012
2answers
Sound, but no picture. Could not identify LCD
Hello
Will you please give me some more details of the fault of your Duraband TV. Give me as much as details as you can; so that I can get into a conclusion and place a solution before you. OK.
5/19/2011 9:26:18 PM • Durabrand... • Answered on May 19, 2011
Want to know if i can purchase a new plug for my
Hi craz... this is a walmart brand. Take your player to a walmart, go into the electronics dept. and they should be able to assist you. Joe
Thanks for choosing Fixya!
3/27/2011 4:19:26 PM • Durabrand... • Answered on Mar 27, 2011
My daughter's player says no
Still under warrenty exchange for a new one or getting it warrenty repair.Happen to all DVD Disc?If some disc only,disc might have scatches,cracks or dirt or grums on it prevent the laser eye from reading it.The DVD player might have dirty Laser bubble eye reader.Tries take some Q tips dipping rubbing alcahols clean the laser bubble eye reader.
1/11/2011 8:35:03 PM • Durabrand... • Answered on Jan 11, 2011
0answers
The battery pack is installed
Check if the fault is if the battery is well connected into the player.
The battery might not be good irrespective of it being a new one or not.
Also, The charger for your player might be defective.
You need to do a general troubleshooting in order to detect actually where the problem is coming from.
So, you can test the charger with another player of this kind, like wise the battery.
I hope you understand the above suggestions.
Good luck.
8/14/2010 1:36:34 PM • Durabrand... • Answered on Aug 14, 2010
I have a JWS or Durabrand DPX3290L dvd player and
This seems like your "Backlight" is either faulty, or the power supply, or inverter driving it is faulty. This Make & Model isn't very well supported, i have searched the 'net, but have been unable to find a service manual, or any manual, which, one really does need, if only for the part numbers to reorder spares.
In saying that though, there is nothing "Special" about them all. They all use a fairly standard type parts. So if you disassemble, the unit, and locate the backlight, and they have a part number on them, you would be able to get the part, from Ebay, or by contacting the maker of the backlight directly. You really need to check the voltage is coming out of the driver, and it actually the lamp itself. But as I said before one really needs a service manual to be able to do that.
http://hackaday.com/2005/11/01/lcd-backlight-replacement/
Have a look at this tutorial above.
6/22/2010 1:30:44 AM • Durabrand... • Answered on Jun 22, 2010
It won't power on. i think the ac adapter has a
You seem to have trouble shot the problem yourself. You need to get a power supply to suit, have a look on the PSU, it should have Voltage and Amperage on it, say like 12 Volts 2.5 Amps.. Now simply get a supply with exactly the same Voltage, and the Current rating must be the same or HIGHER, It is usually the Plug, that may cause problems. usually Radio Shack, or the like, or eBay will have them.
3/7/2010 3:07:40 AM • Durabrand... • Answered on Mar 07, 2010
We have a portable dvd model # dpx3290l , it
put the fire out!
11/13/2009 11:52:02 PM • Durabrand... • Answered on Nov 13, 2009
MY DVD PLAYER WONT READ ****
It won't, it's not designed to read ****, just dvd and cd discs.
But if you have been trying to use it to read **** then you possibly have **** on the lens. It often happens when you use it as intended too.
Try using a regular lens cleaning disc first but if that doesn't work then either the laser or the head transportation system has failed.
They CAN be replaced, but Durabrand are one of those 'no name' ultra-budget brands which just buys in generic products from China and has it's name put on the front.
This means that the internal transport mechanism could be from any of a number of manufacturers. It'll cost you $25 or so just to have it opened up to try and identify whether spares are available, or if you're reasonably technically minded and have an anti static mat or wrist strap you could open it and check for yourself.
If parts are available, then they're likely to cost in the order of $40 -$45 plus shipping, and then you may have fitting costs as well. Sorry, but I'd argue that when you can buy a used portable DVD player in full working order for around $60 and brand new ones for around $90 then it's uneconomic to repair this one.
If you do throw the machine away, list the remote control handset on an auction website. You can often get an easy $15-$20 even for obscure brands like yours.
7/1/2009 10:26:42 PM • Durabrand... • Answered on Jul 01, 2009
Hola como puedo actualizar mi tv Durabrand modelo ON32F6000D. Solo me sale actuazar por USB.
if your Durabrand TV model ON32F6000D offers updates via USB also, Make sure the USB drive is empty and has enough space to accommodate the firmware update file. then Copy the downloaded firmware update file from your computer onto the root directory of the USB flash drive
8/19/2023 11:55:01 PM • Durabrand... • Answered on Aug 19, 2023
BATTERY FOR DURABRAND DUR-7
Six AA batteries.
8/15/2021 7:49:25 AM • Durabrand... • Answered on Aug 15, 2021
My durabrand pdv-709 will only play when i hold down the play button
bad play button
3/31/2021 5:58:35 AM • Durabrand... • Answered on Mar 31, 2021
Does the Durabrand AD980BD dvd/vhs combo record vhs onto dvd?
It is a DVD player and VHS recorder.
3/3/2021 10:06:50 AM • Durabrand... • Answered on Mar 03, 2021
Durabrand DPX3290L Player Logo
19 questions posted
Top Durabrand Televison & Video Experts
matt martin
matt martin
ZJ Limited
ZJ Limited
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Durabrand Televison & Video
Most Popular Question
portable dvd model dpx3290l
  • Televison & Video
