20 Most Recent
Venturer PVS8380 Player Questions & Answers
Venturer pvs 123 instruction manual
Here it is:
http://videogame.manualsonline.com/manuals/mfg/venturer/avm670_pvd73_pvd880_pvs123_pvs125a_pvs126a_pvs166w_pvs177g_pvs1071_gen36.html
My dvd player has a good dvd in it but it says it
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can not read the disc. The only option is to gently clean the laser lens with a Q-tip and rubbing alcohol and allow several minutes to dry, if this fails, cheaper to buy new than repair.
How do i know when the dvd is charging?
When you first plug it in, the green led should flash for a few seconds. It will then go on solid green while charging. The green led turns off after it thinks the battery is fully charged. Not sure what it does with a defective battery but this is the basic charge sequence.
Wont spin disc
OK. Best way is to check whether the drive motor is running or not. If u have warranty go get that opportunity and repair with free cost. if dont, better find an electronic expert and get fix it.
Dont panic its not that costlier for that motor.
Where can I find a replacement monitor cord for a Venturer PVS1961?
It may be difficult to find a replacement monitor cord specifically for the Venturer PVS1961, as it is an older model. You can try searching online for "Venturer PVS1961 monitor cord" and see if any results come up. If you're unable to find a replacement cord, you may want to consider purchasing a universal monitor cord that can be adapted to fit your device.
It's possible that you are missing other cords, such as a power cord. It is best to check the manual or contact the manufacturer to see if you are missing any other cords.
1/22/2023 4:36:58 AM •
Venturer...
Answered
on Jan 22, 2023
Where can I get the hinge replaced on a 15.4 Venturer tv KLV3915
Please call geeksquad at Bestbuy to setup a repair appointment. There phone number is 1 (800) 433-5778. You can mention the tv model that you've mentioned here and they should then confirm their ability to repair the hinge. You might have to email a picture in so that you don't have to carry the tv to the store. Geeksquad might even be able to pick up the tv for you if they determine that they can do the repair.
Thank you.
10/10/2022 11:04:39 PM •
Venturer...
Answered
on Oct 10, 2022
