20 Most Recent
Samsung LN52B750 52 in. LCD TV Questions & Answers
I have a Samsung model LN52B750 flat panel, and
I have a Venturer Model PLV36220S1 that fail to come on. When the ON BUTTON is depressed the screen light up in a gray color and stay on for approx. 5-7 seconds then go black.
Any solution, is it worth attempting to repair?
Delete software upgrade
If you've a latest software than the TV has now installed, you can do it by an upgrade with that software. As the process goes on, the older version will be deleted. You cannot delete the software by any way. If you wish to get more details, surf the
following link. There are over two thousand and four hundred posts. All are
related to television and other domestic electronic equipment service help. You
can get a solution there. Type in the brand name to your device to its search
box, can be located at the top right of the display window.
Have a samsung LN52B750 that
The problem is that there is a burnt or bad capacitor on the power supply board of the television, it is not longer responding, while it tries to respond is when you get the clicking sound, therefore it is not going to power on until the bad capacitor is replaced.
Run a check on the power supply board, you will definitely see the bad capacitor, have it replaced and the television will turn on after reassembling the television back together.
Thank you for using fixya
Caseytech
Turn TV on and off itself
There are so many reasons for this fault. From main power supply regulator up to display panel should be checked. This is a very skilled work, that a user can't do it. Contact any experienced service technician.
Broken screen ln52b750
It is a fatal case as the screen which is called a panel unit is more than the set cost new, sorry but it is the end for this set.
My tv screen is totally
p { margin-bottom: 0.21cm; }
Hi,As you mentioned your tv have
problem with the T con board. Normally in an lcd tv he t con board
drives the millions pixels in the lcd panel in rows and columns. if
any of the driver or a group of driver for rows and columns is fulty then the
respected row or column will be missing in the picture. This
problem can occur under two circumstances fist is if there is any
loose contact in the connections of the board. if so remove all the
connection to the t con board and then reconnect it. There are total
six connections in the t con board. Of which five will got the lcd
panel and one will go to the mother board.if there is any loose
contact removing and refining the connections will solve the problem.
If not then you have to replace the T con boar. Normally you
can find the t con board in the bottom centre or top centre of the
lcd Covers with metal cover or aluminium foil. I have added the
picture of the t con board for your tv. I you need any more
assistance feel free to contact me through fixya.Ajin
I have a Samsung 52
easy fix. check here: http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Getting double vision when first turned on. Goes
You may have the capacitor in power supply defect. IF you want to repair your self.. look on the power board for swollen capacitors. OR contact Samsung consumer relations and most likely you will get an authorization to repair set at no cost. JUST describe the problem as the set wont play until it heats up and they will contact your local service center. This problem is well known in the service industry.
I have a Samsung LN52B750
This tv has not gotton hit by any object or someone.Than it not the LCD panel screen problems.This cause it the T-CON decoding board is dead,that sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
The capacitors were replaced now we are
Hopefully a cable came loose and just needs to be "reseated" or connected. Try checking all cables you had to mess with when the caps were replaced, and reseat (unplug and replug) anything easily accessable. Reseating cables can fix issues a lot of times on cables that have lots of connections. Be very careful you don't break anything, some cables with clips can break if you don't unplug correctly. Ribbon type cables can get plugged in crooked or the little strips of metal can peel back when you plug them in. A trick on ribbon cables is to mark them with a marker right down the connector before you ever unplug them, that way you can see that you plugged it in all the way and are not crooked. Let me know if I can be of further assistance.
