20 Most Recent LG 42LH30 42 in. LCD TV Questions & Answers
My LG 42LH30 gets red power light but wont turn green?
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
9/15/2015 12:25:48 PM • LG 42LH30 42 in.... • Answered on Sep 15, 2015
How do i fix my lgtv wiht one side not showing no picture
I know this sounds strange but try twisting the tv frame back and forth. Once upon a time it worked for me.
3/3/2015 5:01:21 PM • LG 42LH30 42 in.... • Answered on Mar 03, 2015
Have an LG #42LH30 colored stripes down left side static on right
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
12/5/2014 1:25:29 PM • LG 42LH30 42 in.... • Answered on Dec 05, 2014
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
7/20/2014 5:50:20 PM • LG 42LH30 42 in.... • Answered on Jul 20, 2014
0answers
I turn on the tv and only half of the sreen can be seen it
In such cases it is the TCON board which is found to be responsible most of the times.
12/23/2013 4:38:45 AM • LG 42LH30 42 in.... • Answered on Dec 23, 2013
The screen goes dark after a few seconds of it being turned on
There is nothing you can do about it by yourself. Consult some qualified technician or service center .
12/22/2013 1:30:22 PM • LG 42LH30 42 in.... • Answered on Dec 22, 2013
I turn on the tv and only half of the screen can be seen
A clear proof to some loose soldered point at its circuit board, or a loose contact with some cables. You should check and find which one causes the fault.
11/26/2013 4:04:48 PM • LG 42LH30 42 in.... • Answered on Nov 26, 2013
I have an LG 42LH30 set and the picture is dim but
how about the backlight have you been check if some parts are not working or need replacement.
11/2/2013 2:10:03 AM • LG 42LH30 42 in.... • Answered on Nov 02, 2013
LG 42LH30 42 in. LCD TV Logo
100 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
screen goes dark after few seconds being
  • Televison & Video
