If you are talking about the power button :
You should not get voltage out of the switch it should read a short to ground when the button is pushed as the resistance it measures to ground tells the micro which button is pressed.
You more than likely have a fialed button assy, which is common because the buttons get pressed when it is set on a hard surface ( i have to admit i have broken a button on this set before)
It can be hard to change the buttons because on mine i had to remove the front cover to change them.
I could not find the part number for the button assy/keypad assy but the button is easy to change just 2-4 pins to unsolder and resolder, if you dont want to order the button you could just steal the volume or channel button and replace those later.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
50 questions posted
2,254 Questions
610 Questions
478 Questions
339 Questions
330 Questions
