20 Most Recent
Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Questions & Answers
There is no sound on my insignia flat screen what do I do
Try hooking up the powered PC speakers to the AUDIO Line out RCA jacks to see if you get the sound there, if you do, then the problem can be in the power amp section (make sure to check the on screen sound setup menu that the speakers are not set to OFF), if no sound at the RCA jacks either, then the problem can be in the sound processor circuit in the main board.
11/16/2023 3:54:34 AM •
Insignia...
Answered
on Nov 16, 2023
Tv does not work since everything has gone digital
You have to use a digital adapter box for your TV. The government was subsidizing these boxes to citizens who did not have some sort of cable service. You can pick one up from the store for about $40. Connect your antennae to this box and then this box to your tv. Antennae--->box--->TV. The box will adapt the local stations in your area that are now being broadcast in digital form to your TV. Hope this helps.
12/3/2016 2:38:34 AM •
Insignia...
Answered
on Dec 03, 2016
Rcr312wr universal remote to insigniatv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
12/29/2015 8:40:07 PM •
Insignia...
Answered
on Dec 29, 2015
Debug apears on left side always
Firmware corrupted. Do a firmware update. Contact any experienced service technician, of the authorized service centre to Insignia. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/28/2014 5:52:52 PM •
Insignia...
Answered
on Mar 28, 2014
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
1/3/2014 7:11:55 AM •
Insignia...
Answered
on Jan 03, 2014
Tv wont turn on
does the light stay or blinking and how about the screen display totally black or a white screen. you can see in a dark room if their is a white screen. if totally black screen then with sound the cause is could be bad inverter board or screen back light. if a white screen it was the t-con board not working good.
10/5/2012 5:16:58 AM •
Insignia...
Answered
on Oct 05, 2012
The back of the tv gets hot
It is OK. This is not a fault. Heat will be generated when an LCD TV works. This is common for all brands. It is not a fault.
8/12/2012 3:23:47 PM •
Insignia...
Answered
on Aug 12, 2012
Codes for insignia tv with dish controller
For more details Type in this site name < Electro-help> (DO
NOT copy and paste the site name from here.
Doing so may lead you to wrong place) to search box of your search
engine [not in the address bar of your browser],
and press "Enter".
It is an electronic
equipments service help site.
Note the
position of hyphen in between words in site name. The site will appear as it is in
web; subtitled as Service help to electronic home entertainment equipments.
You can locate this site,
either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
6/8/2012 4:40:17 PM •
Insignia...
Answered
on Jun 08, 2012
