20 Most Recent
Toshiba Regza 52XV645U LCD TV Questions & Answers
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
I have a Toshiba
Good afternoon; I just buy a toshiba 17MB16P-2 TV without manual; when I switch it on it just gives me a message of welcome and tells me that there is no signal; I don"t know what to do. I will also be very greatful to have the manual of this tv in order to know how to manipulate it. I am expecting yours solutions. once more good afternoon to you.
52xv645u is dead no power or 5v
Power supply is the suspect on this one. You will have to isolate the power supply in the unit and check the voltages on the input and the output side to verify it is or is not the problem.
Tv will not turn on
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.Good luck!
We have Toshiba Regza 52XV645U. We have dish
This sounds like what may be causing it is the cable going from the tv to the receiver box. If it is only happening on the sat channels, you know that it's not the tv. I would replace the cable, if that does not work, then it may be that the receiver needs to be replaced.
Becki Barned
DISH Network Customer Service
My Toshiba 52XV645U shuts off spontaneously after
Now,tv power up and picture come up and work normal again now wright?Only happen one time,than it just a power glitch.Happen often,than the power supply board is dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
