20 Most Recent
Proscan 37LC30S60 TV Questions & Answers
Its plugged in the red
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
First repair the power supply's capacitors and then any other component if needed :)
Please rate if this helps :)!
3/7/2011 7:42:52 PM •
Proscan...
Answered
on Mar 07, 2011
I have more than one A/V cable to connect to the
This is actually really not good don't use a composite with a component input go to the store and buy an HD cord for you're wii if you need help ask the person in the store for a component cable for the wii.
2/5/2011 11:07:21 PM •
Proscan...
Answered
on Feb 05, 2011
How do I plug in more then one units i.e Wii, DVD
You cannot get color when connecting a composite cable to a component input. Unfortunately you will have to connect the Wii to the composite input when you want to use the Wii and then disconnect it and connect the DVD player to the composite input when you want to use it and etc.
10/15/2010 4:00:55 PM •
Proscan...
Answered
on Oct 15, 2010
Proscan TV m/n 37LC30S60. The
Look for Bad Capacitors on the power supply board,they will be vented,swollen or puffed up on TOP. 2200uf 10v 3300uf10v
Call Encompass Parts Distribution for service manual or visit their Website and type in model#
1-800-638-3328
9/30/2010 2:21:49 PM •
Proscan...
Answered
on Sep 30, 2010
I have a 37in DVD combo they install my cable
You most likely need to access your menu screen and change the setting of the input to "catv" from "antenna" if this does not fix the problem your tuner module has developed a problem and will need to be replaced.
5/8/2010 7:20:29 PM •
Proscan...
Answered
on May 08, 2010
