20 Most Recent
Lorex SG610 Simulated Bullet Style Surveillance Camera Questions & Answers
Can my Lorax mc2700 be viewed from my phone
The Lorax MC2700 is a portable radio that does not have Wi-Fi or Bluetooth connectivity. As a result, it cannot be viewed or controlled from a phone or other device. It can only be controlled using its physical controls
My lorex DVR won't turn on
If your Lorex DVR won't turn on, it is likely that the power cord is not properly connected. Make sure that the power cord is securely connected to the DVR and that the power switch is in the "on" position. If the problem persists, you may need to replace the power cord or contact the manufacturer for assistance.
Lorex dvr beeping
NORMAL ON POWER UP , IT;S TELLING YOU POWER HAS BEEN CYCLED AND OPERATOR NEEDS TO CK THAT SYSTEM HAS RESTORED CORRECTLY ,USE MOUSE TO CLICK BELL ON BOTTOM EDGE OF HOME SCREEN TO CANCEL BEEP !
My Lorex 1080p HD recorder keeps beeping . How can I stop it
This is caused by one of the alarm settings. It could be as simple as motion alarm. It can also be a bad or no hard drive or video loss. So the best thing to do is check everything and turn off the motion alarm and any other alarm you want to turn off. It's all in the admin settings under alarm. Good luck.
