20 Most Recent
Bell Sports Wireless Door Bell with Waterproof Sender Questions & Answers
Siemens model jsjs-210 door bell manual to chnge
Siemens door chime jsjs-210
Without doubt the worst piece of design I've ever encountered.
The battery housing on the chimer is so large that on closing the lid with the batteries fitted they pop out, nothing holds them in place other than the contact elements - the case snaps shut with quite a jolt and the batteries just pop out...had to use a padded envelope cut to size to keep them in place.
Also the button unit is dreadful - the button isn't actually a button - it's a light, pushing the button just flexes the circuit board and activates a small push sensor on the reverse of the circuit board!?! WHY? A button that isn't a button? The sensor is also too short to touch the rear of the casing and thereby close the circuit - had to pad this out with 2 bits of cardboard...too much it will ring all the time, too little it won't connect.
Please do not buy this product - if you have return it, it is dreadful - and from Siemens it's not even funny.
Apologies for not answering the question directly - I was also searching for a manual for this, to maybe figure out why this device is so badly constructed.
Wireless door bell not working
Generally speaking the doorbell with the 1 thru 8 and the receiving unit should also have the 1 thru 8 tabs. Just make both units have the same positions for the 1 thru 8 and you should be all set.
Installed new reg. doorbell on first floor now wireless upstairs
when did this work last?
is the new unit on the first floor designed to work with the 2nd floor unit?transmission,
you may have to tune the 2 units to the same transmission frequency before they will work to gether,some wireless units only have a short range of transmiting distance too
have you checked the power supply to the receiver upstairs and the bell push battery on 1st floor?
they seem to be the most common solutions for this type of device
if its the age of the unit then its time to replace it
