What do you want to know? Provide more details please. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
1. Switch on the set you want to control. 2. Hold down the S key until the key that corresponds to the last mode you selected blinks 3 times and then remains lit. 3. Press the key that corresponds to the type of equipment you want to control: TV: television set, VCR/DVD: video recorder - DVD player. 4. Direct the remote control towards the set and try to switch it off by pressing the key B. 5. If the set you want to control switches off, press OK to memorise the subcode. 6. Should the set not switch off, press key B as many times as required (up to 200 times), until the set switches off. Between two key presses, leave enough time for the key corresponding to the selected mode enough time to light up again (about 1 second). Proceeding this way will enable you to see whether the set responds or not. 7. Immediately upon the switching-off of the set to be controlled, press OK to store the code.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in this key phrase "How to unlock the region code"; in the search box at the top left of the display window, to get gathered related posts.
