20 Most Recent Panasonic TC-P42X1 41.6 in. Plasma HDTV Questions & Answers
4 blinks code
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/ Blinking codes details of many popular brand TVs are given. Surf the site with patience.
12/12/2015 6:19:39 PM • Panasonic... • Answered on Dec 12, 2015
Why is there a solid horizontal green line in middle when set is on?
CCFL lamp in the back-light system fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/6/2015 5:50:52 AM • Panasonic... • Answered on Nov 06, 2015
Can my Panasonic TC-P42X1 receive
No.Tv can't pick up any reception or receive any free AIR broadcasting tv channels at all if tv have no antena hook up to a tv.Buy a better antena design to used like a Digital atenna,will solved this problems.
2/21/2015 2:17:20 AM • Panasonic... • Answered on Feb 21, 2015
What I do to fix the black screen?
The fault can be on the Ysus,Xsu,or buffer boards you need to takeit to a repair shop for diagnosis
2/9/2015 10:32:50 AM • Panasonic... • Answered on Feb 09, 2015
2answers
Need activation code for netflix?
Need the activation code for netflex on the panasonic TC-P42X1 have a wireless router to my blue ray
6/29/2014 7:37:21 PM • Panasonic... • Answered on Jun 29, 2014
9 red flashes
The power supply needs repair or replace and that will fix the porblem. Get a new one at www.partstore.com
3/15/2014 1:13:20 AM • Panasonic... • Answered on Mar 15, 2014
Looking for a power cord for this tv
Hi Virgina any electronics shop like Kmart or the like should be able to help
1/25/2014 11:58:26 PM • Panasonic... • Answered on Jan 25, 2014
The TV dosent star up only flashing power led
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
1/5/2014 9:49:04 AM • Panasonic... • Answered on Jan 05, 2014
Just started to see "wavy lines" on the picture screen.
There are two main reasons for this fault. The first one is insignificant signal strength. The second is, with its output voltage from the main power supply regulator board. It is best to contact any service technician. google.com/+GopakumarGopalan
12/7/2013 5:27:04 PM • Panasonic... • Answered on Dec 07, 2013
Blinks red wont come had it diagnosted tech says main board
I had same problem with my Hisense TV. I replaced the "Main Board" and it's working fine. I took the TV apart and got the part # off the main board and checked ebay...found one! Good luck.!!
12/1/2013 10:42:15 AM • Panasonic... • Answered on Dec 01, 2013
I have a panasonic model number TC-P42X1 and i have no picture or sound. and the red light flashes every 4 seconds none stop
I had a similar problem with my Hisense TV and I replaced the "Main Board". Got the part on ebay. Don't know if this will help. Good luck!
12/1/2013 10:39:22 AM • Panasonic... • Answered on Dec 01, 2013
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
7/18/2013 1:13:37 AM • Panasonic... • Answered on Jul 18, 2013
Panasonic TC-42PX14 wont turn on power light flashes 1 time
You may want to shop for that board or at least consider removal of the HDMI socket in question---tested for shorts there I presume?
11/5/2012 11:24:48 PM • Panasonic... • Answered on Nov 05, 2012
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
9/4/2012 1:55:35 PM • Panasonic... • Answered on Sep 04, 2012
Pink screen no sound panasonic tc-p42x1
tried to hooked up only an areal antenna if still the same problem. just to ensure if the problem is only in the tv .
8/14/2012 1:30:34 PM • Panasonic... • Answered on Aug 14, 2012
Panasonic TC-P42X1 41.6 in. Plasma HDTV Logo
75 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
just started see wavy lines picture
  • Televison & Video
