20 Most Recent
LG W2753V PF Flat Panel 27" LCD monitor Questions & Answers
My lg m2762d lcd tv
makes a difference where this line is... very top, top, middle, bottom, very bottom? also, is this set new to you, or has it been fine for a while, and just started doing this? does the line stay there when you switch to other inputs? (like a dvd player or a gaming console)? this kinda stuff will help you get an answer that makes sense - good luck
Does the lg w2753v flatron
The W2753v does not include speakers so it has no sound capabilities built in, you would need external speakers.
I HAVE A LG Full HD 1080p HDMI W2753V-PF 27-inch
It is the picture picture board on your monitor that is
malfunctioning, i believe the power led button is on while the screen is blank or off, it means the
board of your monitor has developed fault and will need to be replace in other for the screen to display again.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity
or any service center
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
Take care.
The problem is the monitor
if it is not that long since you bought it, i suggest you take it back where you bought it from for a full warantee.
or you could it is has been long since you had it take it to a nearest pc worker for new programming.
thank you
wonder
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
