20 Most Recent
IBM THINKPAD X200 TABLET SL9400 2GB 160GB 12.1-WXGA CR WVB Questions & Answers
Hi, my mom just got a IBM thinkpad. It worked just
Check if you have any button on panel says about to lock the keys and mouse? Use your manual book if you have one. Lenovo has got this buttons that locks the keys and mouse to prevent unautorized use while you are away. Possible located next to the audio or power button.
jmc
When i reformatted my T43ibm thinkpad my sound was
Go to this site and complete the details for you model and operating system. You should find the drivers that you need to reconfigure your system.
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=207196&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
No audio output device is installed
HI,
there might be an issue with your audio card.
- click on start
- right click on computer then properties
- click on device manager
- then check the audio information, if there a ? mark the drivers are not installed
- if there is a ! mark, the drivers are corrupted. and you have to reinstall it again
Cheers!!!
Keyboard key popped off
The key should pop back on... if it doesn't then the brackets on the keyboard for that specific key are broken. The keyboard will still function properly... every key will work fine.
Or buy a new keyboard.. they are cheap.
MY CD DRIVE IS NOT WORKING, HOW TO READ IT, LZ
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment.
If this information was helpful, please take a moment to rate the solution. Thank you
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
