20 Most Recent
Kodak EasyShare ZD710 Digital Camera Questions & Answers
My camera just stopped working
Completely dead? Have you checked the batteries? Did you try some fresh batteries? Did you check the contacts from the batteries and in the camera. They should be clean and shiny. eventually clean with a dry cloth, not with a sharp tool.Were you making lots of pictures in a short time? It could be the camera was over heating and (temporary) shut down. Leave it for a little while and try to use it again.I hope by the time you read this,the problem was solved.
Card write protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How to take automatic pictures
If you mean in automatic mode, turn the mode dial on the back of the camera to the camera icon. If you mean using the self-timer so you can get in the picture, follow the instructions on
this page of the use guide.
ZD710 KODAK CAMERA
Look for the "Date & Time" command in the Setup menu (camera-and-wrench icon).
Flash won't work
maybe some resistor in FLASH CIRCUIT section inside of your camera are opened because sometimes, this is what i find when im experiencing that kind of truoble,so i advice you to try first on the settings menu before consulting to a trained technician,.
Can i use my kodak ZD710 digital camera as a web
I don't know why I bother to keep answering this particular question, because the few who bother to rate my answer rate it as if they hold me personally responsible for the camera's design, but here goes anyway.
No. The ZD710 was designed as a camera, storing high resolution images (and videos) to a memory card. It was not designed as a web cam, to stream low resolution videos live to another device.
My Kodak ZD710 Will only
Welcome to FixYa.
Kodak lithium digital camera battery CRV3 (non-rechargable) approximately can take pictures up to 500 pictures. However, actual life may vary based on the usage.
How to extend your battery life?
1. Use power saving features (using a power saving modes). Limit activites such as reviewing pictures/videos on the LCD.
2. Dirt on the battery contacts can affect battery life. Wipe the contacts with clean,dry cloth before loading the battery in the camera.
3. Battery performance is reduced at temperatures below 41 F(5 degree celcius). When using your camera in cold weather, keep spare batteries warm. Do not discard cold batteries; when they return to room temperature, they may be usable.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
