20 Most Recent
Nikon D5000 Digital Camera with 18-105mm lens Questions & Answers
Can we use a Cobra Auto 150S Compact auto/manual
As a slave, yes, though you won't get any of the features of a Nikon CLS-compatible flash unit. You would be shooting in manual flash mode. Due to its higher trigger voltage, I would NOT put the unit onto the camera itself.
My nikon D5000 monitor is dark and i have to look
The Nikon D5000 must be set in "Live View" mode before you can use the rear monitor to take photos. There is a button that says "LV" to the right of the LCD screen that sets Live View to on or off.
Autofocus not working
Have you tried to see if you camera is running the latest firmware? If its not update it.
Nikon Teleconverter
You could probably use either a 1.4 x or a 2 x, depending on how much you wanted to increase the focal length of your lens. A 1.4 x would give you a range of 98-420, a 2 x would give you a range of 140-600.
Having said that, teleconverters are not usually recommended for use with zoom lenses, and you would lose one stop with the 1.4 x, two stops with the 2 x, thus necessitating longer exposures. Also, with the increase in focal length comes an increased probability of camera shake being more apparent, due to the increased magnification. In your position, I would attempt to get closer to the subject, using a teleconverter as a last resort if this is not possible.
My Nikon D3200 says shutter error can I fix this issue myself?
hi,
did you charge your battery full ? if the battery is not charged enough, it will not drive the shutter opener motor perfectly, and if any type of dirt or friction on the shutter drive gears this will happen, please check the shutter movement by removing the lens.
