20 Most Recent
Mach Speed Trio V430 MP3 Player Questions & Answers
How to get movies on my T2800 Trio Mp3 player
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
The mp4 player will be
i think in 3 possible solutions:
1- try to charge it with another charger
2- connect your mp4 to a computer and run a virus scan, after this try it. if don't, format your mp4 and try to charge it again.
3- the charge system of your mp4 is damaged, so take it to the technical support for to repair it.
How do i recharge it?
When you buy it, it comes with a USB cable and a charger, you juste have to plug it in and it will recharge.
It restarts when I try
I am very sorry you are experiencing this problem. I will be more than happy to help. Try reloading the software. This seems like a software incompatability issue.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
Trio V430 does not come
Welcome to Fixya. It seems that the problem is caused by the battery of your device. It wont take any charge.
You can check the warranty of your device nad if still have warranty you can send it for
RMA
You may be able to get it repaired at no charge if it is under warranty and the malfunction is covered. Mach Speed's warranty information can be found
here
Thanks for using Fixya.
Trio v430 is not recognizing my expansion memory
In this case I'd suggest that you format your player. Contents may be removed by using this function. So make sure to back up your contents. You can sync your player with Windows media payer version 10 or above.
Here is how to format it:
1. Connect the MP3 player to a working USB port. Locate the drive created by the unit, generally just called Removable Disk, with a letter in Parenthesis. Drive letters vary depending on your system configuration.
2. Right click on the removable drive icon which is your player's icon and select format from the drop down menu.
Your MP3 player will now start formating. Follow onscreen instructions and disconnect when format is completed.
Hope this helps.
Where do I sen my
here.
You may reach their Technical Support department by phone at 580.272.0035 or by filling out a contact form
here.
I cant get the volume to turn down
MP3 players have a reset somewhere on the chassis, you should see a small pin hole, use a safety pin and hold it down for 60 seconds to clear the processor so it can reset.
Accidentially deleted some files from my Trio 430
im sorry with a computer stuff that you delete is stored untill more stuff is deleted to write over the top but with stuff like this it is not and if it was deleted from the pc even it will not store them as the files are not native im sorry to give you bad news buy i have answered your question and even though i knew the answer i checked for a long time to see if any programs could restore stuff but *** i thought they cant as there is no were to store the files that have been deleted please make your payment as soon as possible as we have been having trouble with people not paying recently thanks
