20 Most Recent
RCA L26HD35D TV Questions & Answers
RCA L26HD35D has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Rca l26hd35d has no picture
If the Led stays green and you get 24V on the connector to the inverter it's either the Inverter board or the Display is defective. Take the little panel off on the back , upper left side and check for 24 Volts
No picture , but has sound
When that happens you either have loose inverters or you have to replace the inverter board entirely. If you are going the DIY route you may want to grab someone who is entirely familiar with repairing flat panel tvs so that another more serious problem doesn't come from something like this that is relatively simple. Besides making sure the inverter cable is properly reattached to the motherboard you guys will want to go ahead and reseat all of the cables as well.
