20 Most Recent
Frigidaire ATF6700FS Front Load Washer Questions & Answers
Where can I get a manual?
Please go to this link. There you will have your manual. https://www.manualowl.com/m/Frigidaire/ATF6700FS/Manual/287375?page=1
Where is the filter on the ATF6700FS2?
Good Afternoon Friend,
I understand you want to know where the filter is located on your Frigidaire washer, model# ATF6700FS2. The filter is located in the front right hand side of your appliance. It is located between the tub and the drain pump. If you are trying to get to the filter, this is typically not a do it yourself job, as there are no step by step instruction manuals. I would suggest contacting your local authorized technician if you need assistance. They have been trained on your appliance and will be able to best assist. Hope this is helpful.
-Best Regards-
WP
Washing Machine keeps pausing have a error code of 21
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Washer not dispensing water
there is a trap in the large hose between the tub and the pump it needs to be cleaned out, make sure you re-install it properly or you will have worse problems. If you need further instructs I will help you
Washer comes on but no water comes out
Check the water valves to be sure they are on. Then if they are, you may have a controller issue because one of the water valves should work, either hot or cold. If they both stop working it is usually not the valve.
Pause button stuck
I have checked with local supplier and found out that the part number for Affinity atf6700fs1control board is 137006030, since I can not return it, could anyone confirm it for me? Thanks!
Door will not lock
Door lock probably needs repalcing. Try unplugging unit to reset control board first.
Atf6700f
Draining problems usually are a result of a blocked or failed pump. From what I can tell, your model of machine does not have easy access to the pump. However, if you were confident, you could UNPLUG the machine, remove the cover, and inspect the pump yourself, or get someone who is qualified to do so.
