20 Most Recent
QDI Group QDI Advance 6T Motherboard Questions & Answers
Powers up, fans work, but nothing happens. Can not
I will assume that you have everything connected properly and are using the integrated video on the motherboard (not a separate video card installed in a slot). Usually the red light on the motherboard (mobo) is a power-on light, meaning that it is plugged in to a power socket.First try to clear your CMOS settings:Unplug the power cord and remove the CMOS battery for 15 minutes. If your mobo has a BIOS reset jumper, move it to the Clear position and back to normal. If you aren't sure what these things are, it will be in your manual that came with the mobo. Now re-connect everything and try again. Make sure that you are plugging the video cable into the proper socket and your monitor is working. If you can use a DVI cable on that board, try that connector. Make sure your monitor is working.>Visually check for failed capacitors; caps that have ruptured are increasingly common and can stop booting.>Your CPU may have failed; this is a typical situation then the chip fails. Everything works except there is no video on the monitor.For more detailed testing and information, go
HERE.
QDI Group QDI Advance 6T Motherboard memory
make sure you are putting in the correct ram and make sure both are in good, may be registering only one, or maybe one is bad. try them one at a time in each different slot. should tell you if both chips/slots work
I installed a new operating
You also need to install the motherboard specific drivers to activate the various devices (sound etc). The motherboard manufacturer should have the current drivers available for download.
Memory
It means the most your motherboard will support per slot is a 256 RAM. Also, on older systems, some RAMs are not compatible with others.
