20 Most Recent Kenmore 3.8 cu. ft. HE3 Front Load Washer Questions & Answers
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
11/20/2017 9:47:51 PM • Kenmore 3.8 cu.... • Answered on Nov 20, 2017
Kenmore He 3 model 11042832200 water leaking from
If you take the top off, you can see the whole part called the dispenser, https://www.searspartsdirect.com/model-number/11042832200/0583/0153200.html Check all the hoses etc. Yes you can even run the machine with the top off and see where the leak is. To take the top off there are three screws in the back at the top and when you remove those, the whole top lifts a slides back and comes off.
10/14/2017 7:41:48 PM • Kenmore 3.8 cu.... • Answered on Oct 14, 2017
0answers
Kenmore He3 sometimes sound like a jackhammer in spin cycle
Have you tried less items? It could be the load is not balanced. Try placing items around the tub evenly. This unit is about 12 yrs old so it could be a bearing.
5/3/2017 4:41:15 PM • Kenmore 3.8 cu.... • Answered on May 03, 2017
My washing machine is having trouble getting past
YOUR PROBLEM IS DOOR SWITCH OR CLOGED DRAIN PUMP THER SHOULD BE A ACCESS PANEL FOR THE DRAIN PUMP SO YOU CAN GET TO THE PUMP AND UNSCREW THE OUTLET TO UNCLOG DRAIN
4/26/2017 2:14:08 AM • Kenmore 3.8 cu.... • Answered on Apr 26, 2017
My mom's Kenmore HE3 Elite electric dryer vibrates
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
3/24/2017 10:03:16 PM • Kenmore 3.8 cu.... • Answered on Mar 24, 2017
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
11/16/2016 6:04:42 PM • Kenmore 3.8 cu.... • Answered on Nov 16, 2016
F13 and F11 codes pop up
F13 is Dispenser Circuit Error If the dispenser motor is not able to be driven to it's proper position. Check mechanical linkage from dispenser motor to the top of the dispenser Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU) Check Dispenser Motor i snagged this answer from another site i think its a worn bit of plastic as it becomes britten when not always wet much like a boat out of water
2/21/2016 5:04:06 PM • Kenmore 3.8 cu.... • Answered on Feb 21, 2016
What is the cu ft of the drum
Shirley, you answered your own question. Kenmore (((((3.8 cu. ft.))))) HE3 Front Load Washer 3.8 cu ft. drum
2/21/2016 4:34:16 PM • Kenmore 3.8 cu.... • Answered on Feb 21, 2016
2answers
Hello. I installed a new never used Kenmore washer today front load. As soon as we turned the water on at the back of the machine the water stated to enter the unit, Even when there was no power to th
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
3/6/2015 1:12:47 AM • Kenmore 3.8 cu.... • Answered on Mar 06, 2015
Kenmore HE3 starts by itself in "delicate" was cycle and fills with water when not in use. Can all this be caused by a bad selonoid??
Check that the machine is not on an auto delayed start. Strange that it starts itself. If a solenoid fails, 2 things happen. They either don't let water in at all, or they don't stop letting water in. If its not on an auto delayed start, I suggest that it could be a faulty main control board . You can stop the machine by turning the water off and switching the machine off at the socket when not in use.
1/3/2015 12:26:55 PM • Kenmore 3.8 cu.... • Answered on Jan 03, 2015
Washer fills up with water when not in use.
You have a faulty fill valve. located where the fill hose is attached. if it is a hot & cold fill then turn tap off one at a time to check which valve is faulty. Replace faulty valve.
10/4/2014 3:54:48 PM • Kenmore 3.8 cu.... • Answered on Oct 04, 2014
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
9/13/2014 11:37:20 AM • Kenmore 3.8 cu.... • Answered on Sep 13, 2014
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
628 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
installed new never used kenmore
  • Washing Machines
