20 Most Recent Systemax Venture VC PC Desktop Questions & Answers
Update bios Systemax Venture VC PC Desktop
need a specific model # please If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
5/13/2012 2:17:13 PM • Systemax Venture... • Answered on May 13, 2012
0answers
Need restore CD
Step 1: It's possible to recover from that mistake and decompress the drive from outside Windows. You must follow these instructions carefully. First we need to reach the Repair Your Computer region. Download and burn this disc. Windows Vista Recovery Environment ISO X86 version (32 bit) If you can't get it there any longer, you can purchase one for $10 here. High-Speed Repair CD Downloads In case you don't know how to burn ISO files to CD, download the free BurnCDCC burning program from here. TeraByte Unlimited Freeware After you've burned the CD, test that you can boot from it. You may need to use F12 during boot to select the optical drive. After you've verified that, we can proceed.
3/5/2013 6:22:03 PM • Systemax Venture... • Answered on Mar 05, 2013
Pc start up problems
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing. The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error Hope this helps.
12/16/2012 6:57:49 AM • Systemax Venture... • Answered on Dec 16, 2012
Homepage hijacked by start.search.us.com, have tried lots of registered antivirus programs
Download MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ Install , Mind the TRIAL PRO version, UNCHECK, you want the freeware version, Run a FULL SCAN, DELETE ALL RESULTS. If you have to, start in safe mode with networking. ALSO on http://www.filehippo.com/, You can find many usefull FREEWARE programs. Anti Virus...etc. I use AVAST free. ALSO Download CCLEANER at : http://www.filehippo.com/download_ccleaner/. With this you can clean the junk from your system, in TOOLS, STARTUP, disable ALL unnessary programs from Startup to dpeed up your machine. respond to post for further assistance. This is a good place to start.
12/13/2012 3:21:18 AM • Systemax Venture... • Answered on Dec 13, 2012
Tower comes on but nothing loads
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
11/24/2012 10:12:36 PM • Systemax Venture... • Answered on Nov 24, 2012
Grandchildren playing on computer/keyboard and now have no sound did they turn something off?
With some multimedia keyboards, it's easy to mute or turn down the volume from the keyboard. Many Systemax systems ship with this type of keyboard. The volume controls are usually at the top of the keyboard or on the right or left side of the keyboard. However, since there are a number of different styles of multimedia keyboards, I'm not sure which key you would need to find. Look for a key with the speaker symbol (looks like a megaphone). Also look in the bottom right corner of the computer screen for the same symbol. If there is a red circle with a line, then the mute has been enabled. Otherwise, it may be that the volume was reduced. With a mouse it's easy to change the setting; just left click on that symbol in that section of the notification bar.In some cases, speakers do fail. So if changing the volume doesn't work, try a different set of speakers. I hope this helps. Please add a comment with more information about your keyboard or Systemax computer model if you need additional assistance.Cindy Wells
11/22/2012 11:09:20 PM • Systemax Venture... • Answered on Nov 22, 2012
How to upgrade my bios
http://www.atips4pc.blogspot.com/
9/30/2012 8:01:27 PM • Systemax Venture... • Answered on Sep 30, 2012
No audio output device installed
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
if your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers
rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
it might take some time being freehope this helps
9/14/2012 6:45:48 AM • Systemax Venture... • Answered on Sep 14, 2012
Computer has alarm sound when turned on and screen is black
  • INSTRUCTIONS :-
  • 1
    Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
  • 2
    Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
    Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
    • 3
      Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    • 4
      Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
      Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under
    • 7/23/2012 12:04:42 PM • Systemax Venture... • Answered on Jul 23, 2012
      I need help, my computer has a black screen and an alarm sound starts after I turn it on. What do I do?
    • INSTRUCTIONS:-
    • 1
    • 2
    • 3
    • Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
    • 4
    • 7/23/2012 12:03:57 PM • Systemax Venture... • Answered on Jul 23, 2012
      Overclocking in bios made desktop crash.
      clear the bios - locate the little 3-pin jumper labeled with "CLR" or simmilar next to the bios chip/battery. short circuit the free pin with the one next to it (yiou will need to use the jumper that is on there). once you have kept it on for 10 seconds - put it back in to original position and configure your bios (time settings, boot device,...)if you can't find the jumper or you think it's too complicated - unplug your pc from power and remove the bios battery. after 30 minutes install the battery as it was and configure your bios (time settings, boot device,...)
      3/19/2012 9:52:04 AM • Systemax Venture... • Answered on Mar 19, 2012
      0answers
      What is the maximum memory supported for my Systemax laptop model number 104787148
      I have searched and I don't think that is the right model number.
      6/29/2017 6:34:28 AM • Systemax... • Answered on Jun 29, 2017
      Keyboard will not connect
      Do light come on when you boot up computer ?
      3/27/2017 9:58:28 PM • Systemax... • Answered on Mar 27, 2017
      Systemax Venture VC  PC Desktop Logo
      Popular Tags
      1 questions posted
      Top Systemax Computers & Internet Experts
      Ngoro
      Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
      View Most Popular
      Venture Systemax
      • Venture Systemax
      Most Popular Question
      update bios systemax venture vc pc
      • Computers & Internet
