20 Most Recent
Ziotek Media Carousel Plus, Beige Burner Questions & Answers
My carousel is flashing SOS 0r 505 and the doors
Check that it is listed in devices. Then check properties to see if it gives you a code you can search for using your browser. If you cannot find an answer, check the USB cable to carousel and to USB. Then, check out different USB ports. Then check that the door is still free and not jammed. Then unplug and re-plug from electrical source. These can be done in any order you choose, but i would check in device manger first.
Need software for zio cd caroudel/plus for vista
1st - Most Vista era computers are probably 32 bit
2nd - 32 bit software DOES run on 64 bit systems
3nd - CD is 700MB and it is simple to upload the ISO to your google drive and provide a link to the file so it can be downloaded.
4th - if there are special drivers, THEN it may not run on Vista if the drivers do not support it, and drivers were a problem with Vista.
Error code 505?
"505" indicates a motor error, meaning that a motor in the carousel is unable to turn. There are two motors in the carousel: one moves the disk carrier and the other moves the eject arm.
you need to send to repair, is a non resetable error
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
