20 Most Recent
Zhone 6212-I3-200 Router Questions & Answers
How to locked my router
Please visit the link below and see if it helps. :
Let me Know if it works.
Thanks
2/26/2014 7:47:48 AM •
Zhone...
Answered
on Feb 26, 2014
Reset modem to default
modems don't have any settings unless you are referring to a modem/router combo. Routers or modem/router combos, commercial/home grade routers can be reset by locating the reset button, or pin sided hole on the back of the router typically labeled "reset" press and hold for 10+ seconds and this will restore the device to factory settings including passwords.
4/5/2012 2:49:33 AM •
Zhone...
Answered
on Apr 05, 2012
This zhone 6212-13-200 modem continually connects, disconnects
you will need to use the power supply that came with the zhone
router......other power supplies are not interchangeable.
make sure all other items that are pluged into the other phone jacks
have inline dsl filters....do not filter the router...if you have the whole
house filter on the outside of your house you will not need to put inline
filters inside ...
make sure there are no loose connections...
last call you isp provider
2/20/2010 3:52:10 AM •
Zhone...
Answered
on Feb 20, 2010
How do I hook up my Westell wireless router to the
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
2/18/2010 9:39:17 PM •
Zhone...
Answered
on Feb 18, 2010
WIFI PASSWORD
Download a manual for the Zhone 6519 if you don't already have one. (You'll be prompted to set up an account)
Service Support
Connect router to PC by LAN cable then log in through the web interface. Go to wireless settings - you should be able to locate the wi-fi password, pass-phrase or pre-shared key.
