20 Most Recent
Trendware TEW-652BRP Router Questions & Answers
1 need reset password
It is dioscussed in the manual, Read it! it will reset it to the default so you can change and forget it again!
8/21/2014 3:20:37 AM •
Trendware...
Answered
on Aug 21, 2014
How to get the router to start up again
Make sure it is plugged in. There is also a factory reset button on the device. It is tiny and you will need to push it with the end of a paperclip of something similar.
11/30/2013 2:13:57 PM •
Trendware...
Answered
on Nov 30, 2013
I have one router, which
Hello there.
Try to type 192.168.1.1
and login in with your default username and password
Good luck, I hope this will help you
8/28/2011 11:01:39 PM •
Trendware...
Answered
on Aug 28, 2011
I accidently changed the ip
What you can do is open the "Start" menu, go to "Run" or just the search box in Vista and Win7, type cmd
A black screen will appear. Next, type ipconfig
Scroll up to where you see "default gateway"
Type the IP from there into your browser, enter in the admin name and password when it asks you, then you can change the IP address back to whatever you want.
7/22/2011 3:27:15 AM •
Trendware...
Answered
on Jul 22, 2011
I forgot username and password for TEW 652BRP
Take a pen/pencil and hold down the tiny button on the back of the router for 8 seconds. This will reset the router. The default username and password will then be changed to 'admin' and 'admin'. If this helped, please rate me well, thanks!
7/7/2011 7:33:19 PM •
Trendware...
Answered
on Jul 07, 2011
I have recently bought a
First of all, we need to check if your MAC ia able to acquire a valid IP address from your Trendware Router. Please follow these steps to check for your IP address.
Click the Apple logo on the top left of the screen > Select "System Preferences" > Select "Network" under the Internet and Network section then select which connection you'd like to check in the Show drop-down menu. If you're hooked up via Ethernet, select "Built In Ethernet." If you have a wireless network, select "AirPort." Select "TCP/IP" on the Network screen and view your computer's IP address on the subsequent screen displayed on your Mac.
Your Trendware router, by default, has a static IP address of 192.168.0.1 so your MAC should obtain an IP address on that same range. (e.g. 192.168.0.XXX) If you are getting a 169.254.XXX.XXX ip address, then that means that your MAC is not able to communicate properly to your Trendware Router. You need to check and recheck if the WPA2 you entered is correct.
If your MAC is getting a valid IP address (e.g. 192.168.0.XXX) then the problem lies between your Router and the Internet. But since one of your computers is able to get to the net, then try these steps to check your connectivity.
Open utilities > terminal then type "ping -c 4 google.com" without the quotes. You should get a reply from google if you are successfully connected to the internet. Please post here the details you find so I can provide you more detailed steps for further troubleshooting.
Hope this helps
4/24/2011 3:56:41 PM •
Trendware...
Answered
on Apr 24, 2011
I cant log into my
Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
so you will have to reconfigure all of the settings on your router
("admin") and password (either "password" or ((("1234"))) depending on your router) to reconfigure your router settings
hope this helps
2/26/2011 5:11:02 PM •
Trendware...
Answered
on Feb 26, 2011
I can't get the Trendnet address to open so I can
Hi we4here,
Welcome to Fixya. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.10.1. The Default username is admin and the password is admin. Password is case sensitive.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
Thanks for using Fixya.
2/7/2011 9:19:29 PM •
Trendware...
Answered
on Feb 07, 2011
My router tew652brp do not
Launch the Wireless Configuration Utility by clicking on the icon in your notifications are.
Click on the site survey link to view available wireless networks. Select your network and click Connect.
If you have secured your wireless network you will be prompted to enter in the encryption key. Enter it and click Apply.
You will now be connected to the wireless network and the parameters will be saved under the profile link.
10/26/2010 4:31:55 AM •
Trendware...
Answered
on Oct 26, 2010
Can't connect apple iphone or
Have you run the "Wireless Networking Setup Wizard", to configure the router, and to set an SSID, an encryption-level, and to set a password? If not, do it, and then use those settings on your iPhone & on your laptop.
9/19/2010 3:44:05 PM •
Trendware...
Answered
on Sep 19, 2010
