20 Most Recent
D-Link DIR-300 Wireless Router Questions & Answers
Forgot password ?how do i reset with a new
To reset the D=Link back to the default settings -
Press the RESET button at the back of the router and power it up. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the D-Link to your computer's LAN port, open a browser and enter the D-Link;s configuration URL.
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now go to the wireless settings.
To secure your wireless network from unauthorized access,
please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
I tried to connect to the Dlink N300 with my cell
Connect a laptop wired to the N300,
If you cn go online it aint a router issue
Second try going online with a laptop
Third check the Signal Type
B/G/N
Keep it to automatic
Disable Router PIN
Try Different Security WEP/WPAPSK/TKIP
Pppoe
This should be from your internet provider:
usually it is a email and a password.
Sometimes you must use the login info on your modem
Your ISP should be able to supply this info.
Error 80710102
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
I lost my CD driver
You do not need the disc. Using you browser, login into the router using the default IP 192.168.2.1 unless this has been changed and you should be able to configure your router.
How to restore D-Link DIR-300 router to factory defaults
For resetting up your d-link router password you have to follow these steps..
1. open your
browser and type 192.168.1.0 and type user name and password
2.go to
wireless settings
. you can also restore d-link router settings .
3. or you may can press the reset botton on the back of your router .for more technical help contact d-
link Tech Support .i hope this will help you..thanks
I forget my dlink password
Type your router's IP address -192.168.0.1- into your Web browser.
At the login screen, select "Admin" from the drop down menu and enter your admin password.
Once you access the Web configuration screen, click "Setup" in the top menu.
Select the "Wireless Settings" link on the left-hand side.
From there, click on the "Manual Wireless Connection Setup" button.
Scroll down to the field representing my "Pre-Shared Key". If you don't see it, select a security mode from the dropdown menu at the bottom of the screen first.
Type in a new password.
Download cd driver
Google it out.. Try the advanced search.. Or you can use this intitle:index.of DIR- 300 Wireless router driver
Jus type it like that
How do I reboot my
remote reboot:
1) login into router
2) http://$address/sys_cfg_valid.xgi?&exeshell=submit%20REBOOT
where $address is IP address:port of your router
Where is the WPS button on a cannon printer
wps button for printer are in the printer wifiu setup go to setup menu and serach for wifi routers once u find the router try pressing the wifi button on the router within 30 seconds
Cts auto mode is greyed !
u can reset your router to factory settings and update to the latest firmware and after that u must redo your settings that u hat in the router
Disable enable upnp
Login to the router on its default IP address (sticker on the bottom) - there's an option in the settings to disable uPnP - though unless you know what you're doing, I'd recommend leaving it on.
