20 Most Recent
Western Digital TV HD Media Player USB Drive Case Questions & Answers
Quite suddenly, my WD
you probably clicked on a mkv file and I have done this also and them nothing works. Go to system settings and travel down below to factory reset and it will work until you get into a compression setting that isn't in the bata SW. Need new sw for this and should be soon. Hulu plus says so anyway.
I ripped bluray with any
Well there is a option in your player to change the language, like go into Play menu and then Audio there are two or more languages displayed in this Audio menu and you need to select any of one of the language as you want.
post further comments for more help or information....
Good Luck!!
Thanks
This is the copyright protection in its finest nothing much you can do there since all the stuff did not copy you need a special ripping tool. I however cannot give you detailed instructions as this would be against our
TOS terms of service and local copy right laws weather you own the disk or not.
You need a special ripping utility do a good
goggle search you will not go
wrong.
Thanks and please click the accept button Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I ripped Bluray movies using
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
