20 Most Recent Sanyo SCP-2700 Cell Phone Questions & Answers
clean chargin jack,install drivers aaaaaand use original data cable
Sanyo SCP-2700 ... | Answered on Feb 06, 2020
Don't worry .. IMEI Number of your mobile will be use full to find your mobile back. File a complaint to your service provider and give your IMEI number or your set... they will track your phone by the help of local cops....
Thanks for rating Good luck
Sanyo SCP-2700 ... | Answered on Sep 13, 2016
YOU can get your MSL code here this site.
hope this will help you.
Sanyo SCP-2700 ... | Answered on Mar 17, 2016
settings ---reset---delete-----code=0000 ,,,1234
Sanyo SCP-2700 ... | Answered on Dec 26, 2014
usb cable or connecting jack faulty
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Sanyo SCP-2700 ... | Answered on Jun 01, 2014
Mine is doing the same thing make sure your battery is good first to do that all you do is take out the battery beside the gold part that charges it there is a white sticker if its no longer white and if it's red your battery is probably bad witch is easily replaceable you can buy a new one on amazon or eBay but if it's like mine and the battery is still good then it probably needs a new charging port witch I'm in the process of trying to figure out how to fix or get it repaired hope this helped at least a little bit
Sanyo SCP-2700 ... | Answered on Mar 30, 2014
Use the cable to connect the cell-phone to a USB port on your computer. Then, Windows will launch the "Camera Wizard" to help you copy pictures/videos into your computer.
Sanyo SCP-2700 ... | Answered on Mar 23, 2014
Sanyo SCP-2700  Cell Phone Logo
329 questions posted
Top Sanyo Cell Phones Experts
Ekse
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sanyo Cell Phones
  • Sanyo Cell Phones
Most Popular Question
dont know msl code boost scp2700 qwerty
  • Cell Phones
