20 Most Recent
Sony Ericsson T707 Cell Phone Questions & Answers
Ear piece not working
the earpiece is out and you will ether have to use the speaker or a bluetooth unit. if not, i would replace the unit. Also try resetting the unit. This may help...
How do I put phone numbers on the sim card
To copy names and numbers to the
SIM card
1 Select Menu > Contacts.
2 Scroll to New contact and select
Options > Advanced > Copy to SIM.
3 Select an option.
When you copy all contacts from your
phone to the SIM card, all existing SIM
card information is replaced.
To automatically save names and
phone numbers on the SIM card
Options > Advanced > Auto save on
SIM.
3 Select an option.
To save contacts on a memory card
Options > Advanced > Back up to m.
card.
SIM contacts
SIM contacts can contain names and
numbers only. They are saved on the
SIM card.
Free unlock
Hi free network unlock code are unavailable for your sony ericsson t707 mobile so better purchase code from reliable paid online providers ...I will recommend you to visit sites like
Unlock-Zone.com here they are rendering unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your country and network provider.If yes then pay for it and unlock your phone.....
Sony ericsson died and wont switch on
It's likely that you need to reflash the phone software to your phone.
You can do this yourself [detailed instructions and files at se-nse.net]
or just do it at a phone shop or through an online site like Da Vinci
or Wontan.
But something you should try is to remove the battery and take out your
SIM / memory card and then let it sit for a bit before you reinsert the
battery [withouth SIM / memory card] and restart the phone. Hopefully
that'll work, if not then you'll probably have to reflash the phone
software. But you could always check by doing a software upgrade using
SEUS [Sony Ericsson Update Service offered for free here - http://www.sonyericsson.com/cws/support/...
Time display on phone has line through it ,when
Hello,there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phonesGood luck.
No one can hear me
This sounds like an issue with your microphone. If your Sony Ericsson is still within its warranty period then you can return it to sony to be fixed free of charge
Why won't my sony ericsson t707 charge when the
first check whether your charger is ok, if it is working on another mobile, look for corrossion on the charging connector of your phone, if you see it corroded or clogged, power off your handset , remove battery and then clean the contacts with a pin or a small blade.
reinsert battery and try charging.
it should be working now.in a rare case if on connecting charger there is red light blinking and your set is not turning on you have a software crash and need to be updated at a service center.
regards
please comment
