20 Most Recent LG SteamWasher WM2801H Front Load Questions & Answers
2answers
LG washer FE error fills with water and door opens.
filter may be blocked
3/5/2019 1:46:36 PM • LG SteamWasher... • Answered on Mar 05, 2019
Drum light stays on but washer won't power on
look for a blown fuse in panel or a bad door switch drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-0.jpg drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-2.jpg drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-5.jpg drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-9.jpg drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-14.jpg drum-light-stays-but-washer-power-nmtrxuhfc1nopxoeyhsrubgi-2-20.jpg
6/8/2015 10:48:38 PM • LG SteamWasher... • Answered on Jun 08, 2015
Water would not come into washer. cleaned filters
it could be in your hose
12/17/2010 4:06:25 PM • LG SteamWasher... • Answered on Dec 17, 2010
Machine flooding while not in use. Drum fills with
One of the water inlet valves is not closing all the way. I will bet that you live in an area with hard water. The valve likely has a lot of buildup on it, and just can't close all the way now. You might be able to remvove the valve and soak in vinegar before buying a replacement valve.
11/2/2009 3:15:45 AM • LG SteamWasher... • Answered on Nov 02, 2009
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
LG SteamWasher WM2801H Front Load Logo
Popular Tags
17 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
machine flooding while not in use drum
  • Washing Machines
