20 Most Recent Kenmore Elite HE5t Washer Questions & Answers
2answers
Kenmore washer elite will not turn on. The power button beeps but does not light up to continue.
WASHER WILL NOT START: Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary. Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch.. If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start. Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself. Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly. Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on. The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings. By the way my advice is free cuz God is good! All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced Lastly CONTROL BOARD If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures. 25728361-oj31pmt05x02zgdxjxsset5x-3-0.jpg 25728361-oj31pmt05x02zgdxjxsset5x-3-2.jpg 25728361-oj31pmt05x02zgdxjxsset5x-3-5.jpg 25728361-oj31pmt05x02zgdxjxsset5x-3-9.jpg 25728361-oj31pmt05x02zgdxjxsset5x-3-14.jpg 25728361-oj31pmt05x02zgdxjxsset5x-3-20.gif
6/22/2022 8:55:32 PM • Kenmore Elite... • Answered on Jun 22, 2022
We are getting an error code of F 35
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Hope this helps...please post back for further assistance.
Daniel
4/18/2018 1:42:47 PM • Kenmore Elite... • Answered on Apr 18, 2018
Kenmore HE5T F11 Fault The door locks and the
Check the element, level switch pipework and the drum motor. If its a few minutes into the cycle then most likely one of these
1/18/2018 7:09:57 AM • Kenmore Elite... • Answered on Jan 18, 2018
After replacing pressure sensor on kenmore elite HE5t I still get F35 error code. What else can I check?
check the hose,i found one from overloading and the tub going off balance that the hose rubbed up against tub causing a small hole in the tube,one more thing you said you blew through the tube up to the sensor,you want to remove the tube from the sensor and blow down to the tub,soap can build up and clog the part that the tube connects to,happens alot on ge top load washers also try running it in diagnostics,alot of these problems are from using to much soap,you should be using only 2 tablespoons of soap that's it,without being there i would run it through diagnostics and see what you find.also like i said to much soap messes up these machines even ruins the spider gear inside the tub,you can try running the washer with hot water and a cup of white vinegar and see if it cleans out the suds and helps you with this code.
10/1/2017 3:33:20 PM • Kenmore Elite... • Answered on Oct 01, 2017
Kenmore Elite HE5t does not move the wash drum or go into spin cycle.
The drum bearing is likely frozen up.
6/26/2017 9:52:36 PM • Kenmore Elite... • Answered on Jun 26, 2017
0answers
HE5t Steam shows SUD then f35
SUD means there are too many soap suds in the washer. Are you using a front load approved detergent? Are you using the correct amount? or slightly less is better.
5/12/2017 10:39:11 PM • Kenmore Elite... • Answered on May 12, 2017
0answers
Code f29 will not start
The error code F29 indicates a problem with the door lock assembly. I recommend replacing the door lock assembly part number 8183270 searspartsdirect.com Please see the instructions provided below. If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services . SAFETY NOTICE: Be sure to disconnect power to the appliance before performing any repairs. If you are not comfortable with doing any voltage checks that might be recommended, please contact your local service provider for repairs. Be aware that there could be sharp edges inside the appliance that could cause cuts or other injuries to yourself or others. http://www.shopyourway.com/m/questions/1077653
7/3/2015 1:12:07 PM • Kenmore Elite... • Answered on Jul 03, 2015
2answers
2answers
I am getting a F20 code. I did the auto diagnostics and It says I am getting no hot water. What should I replace?
NO HOT WATER CHECK THE WATER INLET VALVE AS THE HOT COILS MAY HAVE GONE BAD U CAN CHECK FOR VOLTAGE AND FOR OHMS.. ALSO MORE LIKELY CHECK UR WATER TEMPERATURE SWITCH IT MAY HAVE GONE BAD , USE A METER FOR OHMS CHECK am-getting-f20-code-did-auto-dn3wi03dqy3vjnwbm4uf5us1-3-0.jpg am-getting-f20-code-did-auto-dn3wi03dqy3vjnwbm4uf5us1-3-2.jpg am-getting-f20-code-did-auto-dn3wi03dqy3vjnwbm4uf5us1-3-5.jpg MAY ALSO WANT TO CHECK UR THERMISTOR ON MODELS WHICH HAVE ONE am-getting-f20-code-did-auto-dn3wi03dqy3vjnwbm4uf5us1-3-9.jpg
6/11/2015 11:26:54 PM • Kenmore Elite... • Answered on Jun 11, 2015
Kenmore Elite HE5t Washer Logo
498 questions posted
Alexander
vince
View Most Popular
Elite Kenmore
  • Elite Kenmore
Most Popular Question
kenmore elite he5t washer model
  • Washing Machines
