20 Most Recent eMachines ET1161-07 Desktop PC Questions & Answers
Pinout for pwr sw
http://www.pcityourself.com/building/frontPanelConnections.php FRONT PANEL CONNECTIONS IN GENERAL. IS THIS WHAT YOU MEAN.
5/18/2015 6:33:10 AM • eMachines... • Answered on May 18, 2015
My emachines desktop ET1161-07 is randomly playing a high-low beep
A virus check might not get all malware. Download Malwarebytes free and do a scan with that. Check the add-ons installed in you browsers and get rid of superfluous or strange ones. Use msconfig to check which programs are loaded at start up. Uncheck unnecessary or suspicious ones. Good luck.
2/7/2015 1:24:36 PM • eMachines... • Answered on Feb 07, 2015
I have an Emachines ET1161-07 which freezes at the E logo. the only way to even reach the BIOs is to remove and replace the CMOS battery; doing this only works once and then the computer freez
This might be a dodgy stick of memory or memory slot. If you have more than 1 stick of memory, see what happens if you just use variations of just 1. Maybe try disonnecting all drives except the one you boot from. And, not sure exactly what you mean by works once and how far it gets after removing the CMOS battery. But does it get far enough to boot from a cd? If it does, try getting hold of a AVG rescue disk this will run a pre-boot virus check which may clear the problem if you're lucky. Obviously you would have to use a friend's machine to burn the disk. Unlikely, but could be a failing powers supply. Borrow one and try it instead. Otherwise, it really sounds like a terminal motherboard issue to me. Godd luck.
2/7/2015 1:11:20 PM • eMachines... • Answered on Feb 07, 2015
2answers
I have an ET1831-03 and the hard drive has gone bad. I know I need to replace the hard drive but I don't have nor can I find anyone selling the recovery disk. The acutal manufacture does not even ca
Buy a hard drive external usb case,they are around 30 pound,take out the hard drive from your pc and put it in the external case and use another pc/laptop to get all your valuable files off the drive that wont boot.
11/7/2014 5:50:08 PM • eMachines... • Answered on Nov 07, 2014
Video displays only running pixels
try changing the monitor, if this fails the video card on the computer needs changing.
9/16/2014 9:31:19 PM • eMachines... • Answered on Sep 16, 2014
Manual for et1161-07
That's easy. Open the side panel of the CPU. Locate the battery on the motherboard. Pull it out. Place a fresh one.
8/11/2014 1:35:45 AM • eMachines... • Answered on Aug 11, 2014
Why cant i find (e machines ) listed in my programs under the start menu ? Is there any where else to go ?
Are you expecting a folder or program called 'e machines'? Many machines come with manufacturer branded bloatware, and many users uninstall this stuff to make their machines run better.
7/2/2014 3:09:20 PM • eMachines... • Answered on Jul 02, 2014
Hdmi port
yes there is but you have to but HDMI card.
3/17/2014 1:19:45 AM • eMachines... • Answered on Mar 17, 2014
How to replace the power supply on an emachines ET1161-07
ANSWERD.
2/11/2014 9:30:15 AM • eMachines... • Answered on Feb 11, 2014
2answers
My Computer Doesn't Turns on when i press power
TRY WITH A OTHER PSU.
9/15/2013 10:07:49 PM • eMachines... • Answered on Sep 15, 2013
2answers
EMachines running XP. Computer kept shutting down
Most likely a hard drive problem. When you get the flashing cursor, it indicates a lack of an accessible Operating System. But, if the drive was good you would get a boot failure indication. I would try booting with an XP disc and look for the HDD (or try F2 when you boot) to get to the BIOS and look for the drives there.
9/3/2013 8:03:37 PM • eMachines... • Answered on Sep 03, 2013
2answers
No power
A) Power On switch is no goodB) Power Supply is no goodDo you wish to perform the simple test, to see if the problem is the Power On switch, or Power Supply?If so post back in a Comment.Also, IS it an eMachines ET1161-07 Desktop PC?Don't want to 'rattle my lips off', if it's a different computer.http://www.directron.com/atxswitch.htmlPost back in a Comment.Regards,joecoolvette
5/7/2013 4:18:26 PM • eMachines... • Answered on May 07, 2013
Hook up pc tv
Need more information. Are you using VGA, HDMI S-Video?
4/29/2013 7:33:00 AM • eMachines... • Answered on Apr 29, 2013
2answers
MY EMACHINES COMPUTER IS STUCK IN SAFE MODE
hi ...
whn you say the computer boots up in safe mode..
in this list you should have an option called as load windows normally (similar to this)
use the arrow keys and select it.. and then press enter and please do let us know what happens..
it should ideally work...and if it boots up to your desktop please investigate..
4/11/2013 2:18:57 PM • eMachines... • Answered on Apr 11, 2013
2answers
Reset password emachine
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
11/19/2012 9:20:56 AM • eMachines... • Answered on Nov 19, 2012
My emachine keeps dump crashing
it happens when u use ur com continously 10-12 hrss.....
8/23/2012 1:29:12 PM • eMachines... • Answered on Aug 23, 2012
I disconnected the PSU tohave it checked out and now I can not remember what plug goes in which socket.
You can't really make a mistake here. Usually if it fits it's ok.Your biggest plug probably has 20 or 24 pins in it. The extra 4 pins may or may not be attached to the remaining 20. This plugs into your motherboard in the only place big enough to fit it.There is another 4 pin that will probably plug into the left of the CPU fan.All the others can plug into your hard drives & optical drives in any order.
7/16/2012 8:49:33 PM • eMachines... • Answered on Jul 16, 2012
eMachines ET1161-07 Desktop PC Logo
77 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
E eMachines
  • E eMachines
Most Popular Question
emachines et1161 07 freezes e logo only
  • Computers & Internet
