20 Most Recent
Sony HDR-XR200V High Definition AVCHD Camcorder Questions & Answers
The zoom rocker switch on
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
I do not know how
You will need a card-reader (you plug it in your computer using USB). Then it shows up as a normal drive which you can access through 'My Computer'.
My problem is blurry photos.
You haven't switched the camera to "macro" mode by any chance? Flash should eliminate camera shake as the source of the problem. If it isn't macro mode, then it sounds like a fault requiring the repair shop.
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
I CAN'T VIEW VEDIO CLIPS ON MY COMPUTER FROM MY
AVCHD stands for Advance Video Coding High Definition. Its a video format jointly developed by Sony and JVC. Windows pre-installed applications doesn't natively support this format.You would need the supplied software (Picture Motion Browser v.5) to playback or view your media files.Although it's possible to manually import files to your PC [Mac computers would need to have an intel-based processor, imovie'08 or '09, and NO SD (Standard Definition) FILES recorded to be able to transfer videos] still a you would need a mediaplayer software that supports and recognize AVCHD files for playback. AVCHD files are located in the AVCHD folder>BDMV>Stream. Files would have a .mts or .m2ts extension. So either you use the supplied software or invest on a AVCHD compatible video capturing or editing software.Hope this helps... (update may be released within this month for PMB v.5.2 but downloading orig software for this 2010 model cam, would be better to check this site (you can download PMB software if you don't have it): http://support.sony-europe.com/dime/camcorders/hdh/hdh.aspx?site=odw_en_GB&m=HDR-XR200VE
Yellow tint on display screen
hi
you must have a broken wire in the flat ribbon of the LCD (the one for the blue colour).
you have to replace it
cheers
mich
